Monitoring Process Attributes - How?
  • tuhl
    • May 2005
    • 17
    How is it possible to monitor attributes like cpu usage, memory usage for a certain process?
  • cadbury
    • Apr 2005
    • 77
    if you want to monitor a linux process, you can use the ps command
    for example, i monitor cpu usage for the zabbix agent like that :
    i have a userparameter in my /etc/zabbix/zabbix_agentd.conf :
    UserParameter=agentdload,ps -o "%C" -C zabbix_agentd | awk '{total += $1} END {print total}'
    the ps command show only the cpu usage (-o "%C") for the processes named zabbix_agentd. As several lines are returned (one for each process), i use awk to make the total usage
    other options are availiable for memory usage, see the ps manual
    • tuhl
      • May 2005
      • 17
      Re: Monitoring Process Attributes
      I think there should be an "internal" mechanism to monitor these values.
      @Alexei: Are you planning to integrate a deeper monitoring capability for
      processes?
      Yours
      Tom
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Originally posted by tuhl
        @Alexei: Are you planning to integrate a deeper monitoring capability for processes?
        Yes, I am!
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
