Fetch URL
  • sojeshj
    • Apr 2005
    • 9
    Fetch URL
    Can Zabbix fetch a particular URL. I mean I want to check if I can retrieve a logo on a particular URL (website) in a way to check if that website is up and running fine.
    Can Zabbix do that? If so, please let me know how it is done?
    Thanks,
    Soj
  • tbri
    • Apr 2005
    Monitoring web
    Hello.
    What I tend to do is to make a small script (I love python) that does some operation on a web page and prints -1 if it fails, and the time used if it's ok. So I graph the value + set a trigger for <0 which notifies me by SMS.
    -Torvald
    • tbri
      • Apr 2005
      Oops
      forgot to mention that I naturally invoke the script as a UserParameter in zabbix_agentd.conf
      -Torvald
      • sojeshj
        • Apr 2005
        • 9
        Server may be slow
        Thank you Torvald.. Like you said, the script will work when the site (server) is completely down. But what if the apache on the server is running too slow, ie. if the server is crawling and tries to pull out the site for about 5 or 7 minutes, then whole server is as bad as being down and it notify me unless the server/apache service goes completely down. What can be done so that the script compares with the time and notifies?
        • tbri
          • Apr 2005
          Check URL
          I would do something like the following (untested) script to check for elapsed time.
          If you want to go really crazy you could add this bit before the print result line:
          if data.find(PHRASE)==-1:
          result = -1
          where PHRASE is some text you wish to have on the HTML page.
          -Torvald
          #!/usr/bin/env python
          import urllib
          import time
          URL = 'http://www.zabbix.com' # URL to be checked
          MAXTIME = 10 # Maximum allowed time
          starttime = time.time()
          result = None
          try:
          hdl = urllib.urlopen(URL)
          data = hdl.read()
          except:
          result = -1 # Something failed
          else:
          endtime = time.time()
          if (endtime-starttime)>MAXTIME:
          result = -1
          else:
          result = (endtime-starttime)
          print result # Either the duration, or -1 if failure.
          • sojeshj
            • Apr 2005
            • 9
            Thank you Torvald.. Much appreciated. Let me try this script.
            • sojeshj
              • Apr 2005
              • 9
              Need Perl script
              Hi Torvald,
              For some reason, this didnt work for me. Can you please send me the same script in perl (time dependant) so that i can try it out.
              Thanks,
              Soj
