Hi all.
I'm getting a strange problem, my zabbix 1.4.2 running the server on Debian Linux Etch is getting windows agent information perfectly ( I downloaded the windows agent from http://www.suiviperf.com/zabbix/ )
BUT, With ALL Linux Agents I'm getting the same problem. It gets information only on the first check after I create the host and after.
26862:20071008:170707 Before read
26862:20071008:170707 In parse_list_of_checks('ZBX_EOF
26862:20071008:170707 In disable_all_metrics()
26862:20071008:170707 Parsed [ZBX_EOF]
26862:20071008:170707 In process_active_checks('192.168.0.10',10051)
26862:20071008:170707 In get_min_nextcheck()
26862:20071008:170707 Sleeping for 60 seconds
26862:20071008:170807 In process_active_checks('192.168.0.10',10051)
26862:20071008:170807 In get_min_nextcheck()
26862:20071008:170807 Sleeping for 60 seconds
26862:20071008:170907 In refresh_metrics('192.168.0.10',10051)
26862:20071008:170907 get_active_checks('192.168.0.10',10051)
26862:20071008:170907 Sending [ZBX_GET_ACTIVE_CHECKS
felipe.gestao.com.br
26862:20071008:170907 Before read
26862:20071008:170907 In parse_list_of_checks('ZBX_EOF
26862:20071008:170907 In disable_all_metrics()
26862:20071008:170907 Parsed [ZBX_EOF]
26862:20071008:170907 In process_active_checks('192.168.0.10',10051)
26862:20071008:170907 In get_min_nextcheck()
26862:20071008:170907 Sleeping for 60 seconds
26862:20071008:171007 In process_active_checks('192.168.0.10',10051)
26862:20071008:171007 In get_min_nextcheck()
26862:20071008:171007 Sleeping for 60 seconds
26862:20071008:171107 In refresh_metrics('192.168.0.10',10051)
26862:20071008:171107 get_active_checks('192.168.0.10',10051)
26862:20071008:171107 Sending [ZBX_GET_ACTIVE_CHECKS
26862:20071008:171107 Before read
26862:20071008:171107 In parse_list_of_checks('ZBX_EOF
26862:20071008:171107 In disable_all_metrics()
26862:20071008:171107 Parsed [ZBX_EOF]
26862:20071008:171107 In process_active_checks('192.168.0.10',10051)
26862:20071008:171107 In get_min_nextcheck()
26862:20071008:171107 Sleeping for 60 seconds
26862:20071008:171207 In process_active_checks('192.168.0.10',10051)
26862:20071008:171207 In get_min_nextcheck()
26862:20071008:171207 Sleeping for 60 seconds
26862:20071008:171307 In refresh_metrics('192.168.0.10',10051)
26862:20071008:171307 get_active_checks('192.168.0.10',10051)
26862:20071008:171307 Sending [ZBX_GET_ACTIVE_CHECKS
26862:20071008:171307 Before read
26862:20071008:171307 In parse_list_of_checks('ZBX_EOF
26862:20071008:171307 In disable_all_metrics()
26862:20071008:171307 Parsed [ZBX_EOF]
26862:20071008:171307 In process_active_checks('192.168.0.10',10051)
26862:20071008:171307 In get_min_nextcheck()
26862:20071008:171307 Sleeping for 60 seconds
Thanks a Lot.
Felipe.
Thanks a Lot.
Felipe.
