No data to view
  • marc1911
    • Oct 2007
    • 14
    No data to view
    I've successfully compiled zabbix 1.4.2 under CentOS 5 and installed it on the same system as a server and agent working as a VPS under OpenVZ. I can't seem to see any data comming in from the server within the MySQL client. These are my conf files:
    SERVER:
    NodeID=1
    StartPollers=5
    StartPollersUnreachable=1
    StartTrappers=5
    StartPingers=1
    StartDiscoverers=1
    StartHTTPPollers=1
    ListenPort=10051
    #ListenIP=127.0.0.1
    HousekeepingFrequency=1
    SenderFrequency=30
    DebugLevel=4
    Timeout=5
    TrapperTimeout=5
    UnreachablePeriod=45
    UnavailableDelay=15
    UnavailableDelay=60
    PidFile=/tmp/zabbix_server.pid
    LogFile=/tmp/zabbix_server.log
    LogFileSize=2
    AlertScriptsPath=/home/zabbix/bin/
    #ExternalScripts=/etc/zabbix/externalscripts
    FpingLocation=/usr/sbin/fping
    #PingerFrequency=60
    DBHost=localhost
    DBName=zabbix
    DBUser=zabbix
    DBPassword=okidoki
    DBSocket=/var/lib/mysql/mysql.sock
    CLIENT:
    Server=127.0.0.1
    ServerPort=10051
    Hostname=zabbix.cellar.home
    ListenPort=10050
    ListenIP=127.0.0.1
    StartAgents=5
    RefreshActiveChecks=120
    #DisableActive=1
    DebugLevel=5
    PidFile=/tmp/zabbix_agentd.pid
    LogFile=/tmp/zabbix_agentd.log
    LogFileSize=2
    Timeout=3
    These are my LOG files:
    Server:
    32577:20071010:060954 Starting zabbix_server. ZABBIX 1.4.2.
    32577:20071010:060954 **** Enabled features ****
    32577:20071010:060954 SNMP monitoring: YES
    32577:20071010:060954 WEB monitoring: YES
    32577:20071010:060954 Jabber notifications: NO
    32577:20071010:060954 **************************
    32581:20071010:060954 server #1 started [Poller. SNMP:ON]
    32582:20071010:060955 server #2 started [Poller. SNMP:ON]
    32583:20071010:060955 server #3 started [Poller. SNMP:ON]
    32584:20071010:060955 server #4 started [Poller. SNMP:ON]
    32590:20071010:060955 server #6 started [Trapper]
    32592:20071010:060955 server #7 started [Trapper]
    32594:20071010:060955 server #8 started [Trapper]
    32596:20071010:060955 server #9 started [Trapper]
    32598:20071010:060955 server #10 started [Trapper]
    32585:20071010:060955 server #5 started [Poller. SNMP:ON]
    32600:20071010:060955 server #11 started [ICMP pinger]
    32601:20071010:060955 server #12 started [Alerter]
    32606:20071010:060955 server #13 started [Housekeeper]
    32606:20071010:060955 Executing housekeeper
    32610:20071010:060955 server #14 started [Timer]
    32613:20071010:060955 server #16 started [Node watcher. Node ID:1]
    32615:20071010:060955 server #17 started [HTTP Poller]
    32577:20071010:060955 server #0 started [Watchdog]
    32612:20071010:060956 server #15 started [Poller for unreachable hosts. SNMP:ON]
    32617:20071010:060956 server #18 started [Discoverer. SNMP:ON]
    32606:20071010:060958 Deleted 0 records from history and trends
    Agent:
    3636:20071010:063826 zabbix_agentd started. ZABBIX 1.4.2.
    3638:20071010:063826 zabbix_agentd collector started
    3639:20071010:063826 zabbix_agentd listener started
    3640:20071010:063826 zabbix_agentd listener started
    3641:20071010:063826 zabbix_agentd listener started
    3642:20071010:063826 zabbix_agentd active check started [127.0.0.1:10051]
    3642:20071010:063826 In init_active_metrics()
    3642:20071010:063826 In refresh_metrics('127.0.0.1',10051)
    3642:20071010:063826 get_active_checks('127.0.0.1',10051)
    3642:20071010:063826 Sending [ZBX_GET_ACTIVE_CHECKS
    zabbix.cellar.home
    3642:20071010:063826 Before read
    3642:20071010:063826 In parse_list_of_checks('ZBX_EOF
    3642:20071010:063826 In disable_all_metrics()
    3642:20071010:063826 Parsed [ZBX_EOF]
    3642:20071010:063826 In process_active_checks('127.0.0.1',10051)
    3642:20071010:063826 In get_min_nextcheck()
    3642:20071010:063826 Sleeping for 60 seconds
    I can't find out what's wrong. Is there a way to test correct communication?
  • marc1911
    • Oct 2007
    • 14
    I must have asked something realy stupid or I'm the only one having this very weird problem no one dares to respond to.
    I'm really out of solutions and can't seem to solve it myself. So this is my last cry for help! Hope to address someone here.
    Regards,
    Marc
    • nelsonab
      • Sep 2006
      • 1233
      To me it seems your post is not very specific as to what you are looking for. Nothing in your posts jumps out at me as an error, granted I don't spend much time looking through the error logs unless I need to so I'm not all that well versed.
      What specifically are you looking for? Have you run "netstat -tlnp | grep zabbix_server" to ensure the server is running on the right eithernet adapter and port? Have you gone to Monitoring -> Latest Data to see if there is anything comming in for your host? If you are using external checks such as those for MySQL have you tested them from the command line as the zabbix user? Hopefully a little more detail will help someone help you. :-)
      RHCE, author of zbxapi
      • marc1911
        • Oct 2007
        • 14
        I can't seem to receive any data and I'ven't got a clue why? Everything seems to be configured OK. I've compiled Zabiix server and agent again without SNMP support. Who knows? Maybe there's something wrong with this combination. But I get the same result.
        Than I notice that the queue of items to be updated reports a date time of "01.01.1970 01:00:00" per item. That's weird.
        If I telnet to my agent I every thing seems to be OK. E.g:
        # telnet zabbix 10050
        Trying 192.168.2.208...
        Connected to zabbix.
        Escape character is '^]'.
        agent.version
        ZBXD1.4.2Connection closed by foreign host.
        So my conclusion is now that the PHP front end doesn't fire requests to the agent because of the queue items that go back in time?
        What about that?
