Apache 2 + PHP 5 + Oracle 10 Installation on Redhat OEL 5
  • SebD
    • Jul 2007
    • 24
    I've installed on Redhat OEL 5 :
    - Apache 2.2.3
    - PHP 5.2.3
    - Oracle Server 10.2.0.3
    - libsqlora8
    All the installations are ok.
    Separately, Apache, PHP et Oracle are runing.
    But when I try to use the PHP/Oracle connection for Zabbix, there is a trouble.
    Could someone tell me if forget something in my installation?
    Thanks.
    Sébastien
  • SebD
    • Jul 2007
    • 24
    Ok I've reconfigure my php and now I have this error :
    ocilogon() [function.ocilogon]: OCIEnvNlsCreate() failed. There is something wrong with your system - please check that ORACLE_HOME is set and points to the right directory[/apps/zabbix/upload/zabbix-1.4.1/frontends/php/include/db.inc.php:82]
    Error connecting to database
    I've verified : The Oracle_Home, type (Oracle), host, port, name, user and password are ok.
    Is there someone have any idea where it's come from?
    Logs from Apache :
    [Mon Oct 15 14:55:37 2007] [crit] (70023)This function has not been implemented on this platform: DBD: driver for [DBDriver unset] not available
    Thanks!
    Sébastien
    • SebD
      • Jul 2007
      • 24
      Zabbix 1.4.2 and Oracle
      After some tests working with SebD, the following solutions have been applied :
      - > into db.c
      l 147 : char *connect = NULL; ( * was missing)
      l 149 : sqlo_init(SQLO_OFF, 100, 100) ( instead of(SQLO_OFF,1,100) for connections limitations )
      l 565 : //if(!result) return NULL; ( put as a comment )
      l 776 : result=DBselectN(sql,1); ( instead of result=DBSelect(sql); )
      - > into db.inc.php
      from line 30, define your entries for zabbix database
      $DB = null;
      $DB_TYPE = "ORACLE";
      $DB_SERVER = "xxx.xxx.xxx.xxx";
      $DB_PORT = "xxxx";
      $DB_DATABASE = "ZABBIX";
      $DB_USER = "user";
      $DB_PASSWORD = "password";
      from line 81 ( after adding the previous ones )
      case "ORACLE":
      //$DB = ocilogon($DB_USER, $DB_PASSWORD, $DB_DATABASE);
      "(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=$DB_SER VER)(PORT=$DB_PORT))
      (CONNECT_DATA=(SERVICE_NAME=$DB_DATABASE)))");
      first line commented out, second uncommented, $DB_PORT put instead of standard 1521 oracle port
      - > in database schemas creation
      in oracle.sql
      some tables and their indexes do not create correctly. The solution was to remove the single quotes to any decimal number set as default in the script
      in data.sql
      removal of any occuring `
      when plsql asks for values of lt, enter &lt, and for gt, enter &gt
      in images_oracle.sql
      the pictures are located in frontends/php/images/sysmaps/
      - > keep an eye on the user rights so zabbix can access oracle
      seems that Zabbix is now functionnal, under qualification for the moment.
      Frederic.W
      • jgordor
        • 19
        Compilation issue
        Hi!
        With the c source modification, you have any compilation issues?
        Many thanks
        • SebD
          • Jul 2007
          • 24
          Hi!
          After few tests, I can say we haven't trouble with Zabbix 1.4.2.
          It's running well with the changes of Frederic.
          jgordor : we have no bugs in the compilation with this changes.
          Sébastien
          • jgordor
            • 19
            Zabbix server don't connect
            Thanks SebD,
            I was able to compile and install correctly, but now zabbix server is unable to connect to the database (I have 1.1.6 running perfectly).
            Any throuths?
