Compilation of 1.4.2 & 1.4.3 (pre) on RHLES 4 update 4 with libsqlora8 (working with 1.1.6) fails (tried without any plus features, only enable server and with or without client). Also tried with client 9.2.0.6 and 10.2.0.1 (same result)
Compilation of 1.4.1 works as expected, this is the compilation error log on 1.4.2 and 1.4.3 pre:
make[3]: Entering directory `/usr/local/src/zabbix-1.4.3/src/libs/zbxcomms'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/usr/local/src/zabbix-1.4.3/src/libs/zbxcomms'
Making all in zbxdb
make[3]: Entering directory `/usr/local/src/zabbix-1.4.3/src/libs/zbxdb'
if gcc -DHAVE_CONFIG_H -I. -I. -I../../../include -g -O2 -I/home/zabbix/sqlora8/include -I/home/zabbix/sqlora8/lib/libsqlora8/include -MT db.o -MD -MP -MF ".deps/db.Tpo" -c -o db.o db.c; \
then mv -f ".deps/db.Tpo" ".deps/db.Po"; else rm -f ".deps/db.Tpo"; exit 1; fi
db.c: In function `zbx_db_connect':
db.c:158: warning: initialization makes integer from pointer without a cast
db.c:167: warning: passing arg 1 of `__zbx_zbx_dsprintf' makes pointer from integer without a cast
db.c:167: warning: assignment makes integer from pointer without a cast
db.c:169: warning: passing arg 2 of `sqlo_connect' makes pointer from integer without a cast
db.c:176: warning: passing arg 1 of `free' makes pointer from integer without a cast
db.c:176: warning: assignment makes integer from pointer without a cast
db.c: In function `zbx_db_insert_id':
db.c:796: error: syntax error before "sql"
make[3]: *** [db.o] Error 1
make[3]: Leaving directory `/usr/local/src/zabbix-1.4.3/src/libs/zbxdb'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/usr/local/src/zabbix-1.4.3/src/libs'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/local/src/zabbix-1.4.3/src'
If more info is needed please ask.
Many thanks in advance.
Jose Luis Gordo Romero
Making all in zbxdb
