{HOSTNAME} is that a problem?
  • karamelos
    • Oct 2007
    Dear sirs , recently i was install the Zabbix 1.4.2 on Centos 5 from REPEL source.
    well everything is playing normal..i added 3 host computers to watch for availability. I have a basic question. In Monitoring -> Overview , i get a lot of {HOSTNAME} list .. i suppose that hostname must be filled withsomething ?
    Other issue is , if i add a host with DNS selected , then the host computer cannot be found for example, in my resolve.conf file i have
    search domain.local
    nameserver 192.168.1.200
    where my 192.168.1.200 is a dns server with domain controller.
    if i ping to temp-host then i get a reply , but if i create host in Zabbix with temp-host in DNS Name entry then i get that this host is not available!! (
    so . . why i get {HOSTNAME} in the monitoring -> Overview ??
    and why i cannot add host's by hostname ? if i set by ip , then everything is going play normal!
    thank you
  • karamelos
    • Oct 2007
    anyone please?
    • swaterhouse
      • Apr 2006
      • 268
      The {HOSTNAME} is a variable that will get replaced with the real hostname in the email message. There is\was a patch to remove it from the descriptions on the overview page but it hasn;t made it into the official release.
      • karamelos
        • Oct 2007
        So i should ignore it ? is not a problem right?
        • swaterhouse
          • Apr 2006
          • 268
          Correct - its not a problem, you can ignore it.
