Hello All,
We are using Zabbix 1.1.6. Decided to upgrade MySQL database from 4.1 to 5.0.45. Did a mysqldump on 4.1 database and then restore dump with 5.0.45.
After upgrade discovered that zabbix reports some mysql errors.
During login:
SQL error: Duplicate entry '0' for key 1
Query: insert into auditlog (userid,clock,action,resourcetype,details) values (1,1193200862,3,0,'Correct login [admin]')
During enabling/disabling trigger:
Query: insert into alarms(triggerid,clock,value) values(14703,1193200769,2)
Any ideas how to fix it?
During login:
