I have been using zabbix now for a year or so and love it. Not to many problems until recently i get this error in the web interface. It happens when i go to configure->graphs, I pull down the group menu to "all" and host menu "all".
ERROR:
* Error in query [select distinct g.* from graphs g left join graphs_items gi on g.graphid=gi.graphid left join items i on gi.itemid=i.itemid while (g.graphid div 100000000000000) in (0) and ( i.hostid not in (-1) OR i.hostid is NULL ) order by g.name, g.graphid] [You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'while (g.graphid div 100000000000000) in (0) and ( i.hostid not in (-1) OR i.' at line 1]
* mysql_fetch_array(): supplied argument is not a valid MySQL result resource[/var/www/html/supermon/include/db.inc.php:411]
Im not a mysql guru but if there is anything i can do on the db to fix issue I am confident i could do that.
Thanks!
ERROR:
Thanks!
