Some host errors
  • Nivko
    • Nov 2007
    Some host errors
    Im testing Zabbix on a mainserver and it's monitoring 3 other servers, it's fully pinable and reservere dns etc. is correct (not by all of the server, but one does, this won't be the error i think?) This is the config for all my agents (except the hostname is everytime changed)
    # This is config file for zabbix_agentd
    # To get more information about ZABBIX, go http://www.zabbix.com
    # List of comma delimited IP addresses (or hostnames) of ZABBIX servers.
    # No spaces allowed. First entry is used for sending active checks.
    # Note that hostnames must resolve hostname->IP address and
    # IP address->hostname.
    Server=xxxxxx
    # Server port for sending active checks
    #ServerPort=10051
    # Unique hostname. Required for active checks.
    Hostname=xxxx
    # Listen port. Default is 10050
    #ListenPort=10050
    # IP address to bind agent
    # If missing, bind to all available IPs
    #ListenIP=
    # Number of pre-forked instances of zabbix_agentd.
    # Default value is 5
    # This parameter must be between 1 and 16
    StartAgents=5
    # How often refresh list of active checks. 2 minutes by default.
    #RefreshActiveChecks=120
    # Disable active checks. The agent will work in passive mode listening server.
    #DisableActive=1
    # Enable remote commands for ZABBIX agent. By default remote commands disabled.
    #EnableRemoteCommands=1
    # Specifies debug level
    # 0 - debug is not created
    # 1 - critical information
    # 2 - error information
    # 3 - warnings
    # 4 - information (default)
    # 5 - for debugging (produces lots of information)
    DebugLevel=3
    # Name of PID file
    PidFile=/var/tmp/zabbix_agentd.pid
    # Name of log file.
    # If not set, syslog will be used
    LogFile=/tmp/zabbix_agentd.log
    # Maximum size of log file in MB. Set to 0 to disable automatic log rotation.
    #LogFileSize=1
    # Spend no more than Timeout seconds on processing
    # Must be between 1 and 30
    Timeout=3
    # Format: UserParameter=<key>,<shell command>
    # Note that shell command must not return empty string or EOL only
    #UserParameter=system.test,who|wc -l
    ### Set of parameter for monitoring MySQL server (v3.23.42 and later)
    ### Change -u<username> and add -p<password> if required
    #UserParameter=mysql.ping,mysqladmin -uroot ping|grep alive|wc -l
    #UserParameter=mysql.uptime,mysqladmin -uroot status|cut -f2 -d":"|cut -f1 -d"T"
    #UserParameter=mysql.threads,mysqladmin -uroot status|cut -f3 -d":"|cut -f1 -d"Q"
    #UserParameter=mysql.questions,mysqladmin -uroot status|cut -f4 -d":"|cut -f1 -d"S"
    #UserParameter=mysql.slowqueries,mysqladmin -uroot status|cut -f5 -d":"|cut -f1 -d"O"
    #UserParameter=mysql.qps,mysqladmin -uroot status|cut -f9 -d":"
    #UserParameter=mysql.version,mysql -V
    In every log from the zabbix agents:
    19994:20071105:184439 zabbix_agentd started. ZABBIX 1.4.2.
     19995:20071105:184439 zabbix_agentd collector started
     19996:20071105:184439 zabbix_agentd listener started
     19997:20071105:184439 zabbix_agentd listener started
     19998:20071105:184439 zabbix_agentd listener started
     19999:20071105:184439 zabbix_agentd active check started [84.243.254.84:10051]
    Can anybody please help me?
    Thanks!
    UPDATE: Server 2 + 3 fixed, iptables problem, now i get agent.ping problem too.
    UPDATE2: Port 10051 must be open to, but iptables doesn't, searching further..
