Not found Curl library
  • Filter
    I've tried to install Zabbix 1.4.2 as is described in manual.
    Everything is ok, until I type:
    [[email protected] zabbix-1.4.2]# ./configure --enable-server --with-mysql --with-net-snmp --with-libcurl
    Then I see:
    checking for libcurl >= version 7.13.1... no
    configure: error: Not found Curl library
    Some info about my system:
    CentOS 4.5 (final)
    [[email protected] zabbix-1.4.2]# whereis libcurl
    libcurl: /usr/lib/libcurl.a /usr/lib/libcurl.so /usr/share/man/man3/libcurl.3.gz
    [[email protected] zabbix-1.4.2]# uname -a
    Linux salamoun.kofola.net 2.6.9-42.EL #1 Sat Aug 12 09:17:58 CDT 2006 i686 i686 i386 GNU/Linux
    [[email protected] zabbix-1.4.2]# whereis curl-config
    curl-config: /usr/bin/curl-config /usr/share/man/man1/curl-config.1.gz
    [[email protected] zabbix-1.4.2]# rpm -qa | grep curl
    curl-7.12.1-11.el4
    curl-devel-7.12.1-11.el4
    I tried things like:
    [[email protected] zabbix-1.4.2]# ./configure --enable-server --with-mysql --with-net-snmp --with-libcurl=/usr/lib/
    but nothing happens.
    Thank for your help
    Milan
    Install libcurl-dev of version 7.13.1 or higher and you will be all right.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
      There is a install howto on the wiki for CentOS\RHEL. In it is a set of commands to help install the correct version of libcurl
        The libcurl in RHEL/CentOS 4 is too old for Zabbix. So you can build Zabbix without web-monitoring support or you must build newer libcurl yourself.
          I have same problem:
          CentOS release 5.4 (Final)
          I download and install curl from sources without configuration:
          ./configure
          make install
          than I configure zabbix:
          ./configure --enable-static --enable-server --enable-agent --enable-proxy --with-mysql --with-libcurl --with-iobdc --with-ssh2
          and see:
          checking for curl-config... /usr/local/bin/curl-config
          checking for the version of libcurl... 7.21.0
          checking for libcurl >= version 7.13.1... yes
          checking for main in -lcurl... yes
          checking whether libcurl is usable... no
          configure: error: Curl library not found
            I'm using zabbix 1.8.2 on centos 5.4 Final too and there is no problem with libcurl library (installed versions are curl-devel-7.15.5-2.1.el5_3.5 and curl-7.15.5-2.1.el5_3.5). Have you installed the necessary packages?
            yum install curl curl-devel
              Yes I have.
              [email protected]:/tmp/zabbix-1.8.2# yum list | grep curl
              curl.i386 7.15.5-9.el5 installed
              curl-devel.i386 7.15.5-9.el5 installed
                i have a similar issue here..
                checking for the version of libcurl... 7.15.5
                checking for main in -lcurl... no
                configure: error: Not found libcurl library
                What else can be done? I've like downloaded many rpms, but each with its own dependencies makes me go round n round n round...gets frustrating. and i can't do yum updates as this isnt a registered machine. RHEL5
                HELPPP PLEASEEE
                  HELPPP PLEASEEE
                  yum install libidn-devel
                  Zabbix Servers - 1
                  Zabbix Proxy - 145
                  Monitored Servers: ~ 1400
                    # yum install libidn-devel
                    Package libidn-devel-0.6.5-1.1.i386 already installed and latest version
                    Nothing to do
                    # yum list | grep libid
                    libidn.i386 0.6.5-1.1 installed
                    libidn-devel.i386 0.6.5-1.1 installed
                    curl.i386 7.15.5-2.1.el5_3.5 installed
                    curl-devel.i386 7.15.5-2.1.el5_3.5 installed
                    curl.i386 7.15.5-9.el5 base
                    curl-devel.i386 7.15.5-9.el5 base
                      Nothing to do
                      Show config.log
                      Zabbix Servers - 1
                      Zabbix Proxy - 145
                        config.log in attachement
                          Has anyone a solution to this problem. I'm experiencing the same problem on an ubuntu server system.
                          How do I solve this problem, I've installed all the libs needed as far as I can see.
                            The problem seems to be with:
                            --enable-static
                            See this post:
                            http://www.zabbix.com/forum/showthread.php?t=9052
                            It has something to do with libcurl and static linking, which doesn't seem to work.
                            With kind regards,
                            Raymond
                            Online Zabbix tutorials:
                            http://www.zbxtutorials.org
                              You need to install curl libraries, not just curl:
                              yum install curl-devel
                              Announcement
                              No announcement yet.
