hello,
I am on Red Hat Enterprise Linux AS release 4 (Nahant Update 6) and I am trying to build from SPEC into source RPM.
I downloaded the SPEC, Source, and patches from the redhat.fedora site for RHEL4 for the latest 1.4.2 sources.
when I build (rpmbuild -ba zabbit.spec) I get the following errors at the end on build:
I have verified that the /var/tmp/zabbix-1.4.2-3-root-root/usr/share/ *does* exist, however the only directory in there is doc
Did I miss a step somewhere?
Thank you in advance
Making install in upgrades
make[1]: Entering directory `/usr/src/redhat/BUILD/zabbix-1.4.2/upgrades'
make[2]: Entering directory `/usr/src/redhat/BUILD/zabbix-1.4.2/upgrades'
make[2]: Nothing to be done for `install-exec-am'.
make[2]: Nothing to be done for `install-data-am'.
make[2]: Leaving directory `/usr/src/redhat/BUILD/zabbix-1.4.2/upgrades'
make[1]: Leaving directory `/usr/src/redhat/BUILD/zabbix-1.4.2/upgrades'
make[1]: Entering directory `/usr/src/redhat/BUILD/zabbix-1.4.2'
make[2]: Entering directory `/usr/src/redhat/BUILD/zabbix-1.4.2'
make[2]: Leaving directory `/usr/src/redhat/BUILD/zabbix-1.4.2'
make[1]: Leaving directory `/usr/src/redhat/BUILD/zabbix-1.4.2'
+ rm -rf '/usr/lib/libzbx*.a' upgrades/dbpatches/1.4/oracle
+ rm -rf /usr/share/zabbix/create
+ chmod -x src/zabbix_agent/eventlog.c
+ /usr/lib/rpm/find-debuginfo.sh /usr/src/redhat/BUILD/zabbix-1.4.2
0 blocks
find: /var/tmp/zabbix-1.4.2-3-root-root/usr/lib/debug: No such file or directory
+ /usr/lib/rpm/redhat/brp-compress
+ /usr/lib/rpm/redhat/brp-strip-static-archive /usr/bin/strip
+ /usr/lib/rpm/redhat/brp-strip-comment-note /usr/bin/strip /usr/bin/objdump
Processing files: zabbix-1.4.2-3
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/etc/zabbix
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/sbin/zabbix_server
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/etc/init.d/zabbix
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/etc/logrotate.d/zabbix
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/etc/zabbix/zabbix_server.conf
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/var/log/zabbix
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/var/run/zabbix
Executing(%doc): /bin/sh -e /var/tmp/rpm-tmp.4235
+ umask 022
+ cd /usr/src/redhat/BUILD
+ cd zabbix-1.4.2
+ DOCDIR=/var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-1.4.2
+ export DOCDIR
+ rm -rf /var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-1.4.2
+ /bin/mkdir -p /var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-1.4.2
+ cp -pr AUTHORS ChangeLog COPYING FAQ NEWS README /var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-1.4.2
+ cp -pr 'docs/ZABBIX Manual v1.4 rev 9.pdf' upgrades/dbpatches dbinit /var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-1.4.2
+ exit 0
Processing files: zabbix-agent-1.4.2-3
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/sbin/zabbix_agent
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/sbin/zabbix_agentd
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/sbin/zabbix_sender
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/sbin/zabbix_get
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/etc/init.d/zabbix-agent
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/etc/logrotate.d/zabbix-agent
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/etc/zabbix/zabbix_agent.conf
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/etc/zabbix/zabbix_agentd.conf
+ umask 022
+ cd zabbix-1.4.2
+ DOCDIR=/var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-agent-1.4.2
+ export DOCDIR
+ rm -rf /var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-agent-1.4.2
+ /bin/mkdir -p /var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-agent-1.4.2
+ cp -pr AUTHORS ChangeLog COPYING FAQ NEWS README /var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-agent-1.4.2
+ exit 0
Processing files: zabbix-web-1.4.2-3
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/etc/zabbix/zabbix.conf.php
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/etc/zabbix/db.inc.php
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/etc/httpd/conf.d/zabbix.conf
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/audio
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/conf
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/images
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/include
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/js
error: File not found by glob: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/*.php
error: File not found: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/css.css
error: File not found by glob: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/audio/*
error: File not found by glob: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/conf/*
error: File not found by glob: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/images/*
error: File not found by glob: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/include/*
error: File not found by glob: /var/tmp/zabbix-1.4.2-3-root-root/usr/share/zabbix/js/*
+ umask 022
+ cd zabbix-1.4.2
+ DOCDIR=/var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-web-1.4.2
+ export DOCDIR
+ rm -rf /var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-web-1.4.2
+ /bin/mkdir -p /var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-web-1.4.2
+ cp -pr README /var/tmp/zabbix-1.4.2-3-root-root/usr/share/doc/zabbix-web-1.4.2
+ exit 0
Processing files: zabbix-debuginfo-1.4.2-3
RPM build errors:
0 blocks
+ umask 022
+ cd zabbix-1.4.2
+ export DOCDIR
+ exit 0
+ umask 022
+ cd zabbix-1.4.2
+ export DOCDIR
+ exit 0
+ umask 022
+ cd zabbix-1.4.2
+ export DOCDIR
+ exit 0
RPM build errors:
