db.inc.php error
  • magua
    • May 2005
    db.inc.php error
    When loading the index.php i get the following error.
    Warning: mysql_num_rows(): supplied argument is not a valid MySQL result resource in /www/htdocs/zabbix/include/db.inc.php on line 136
    How can this be corrected? Any ideas?
    Mike
  • matboy
    • May 2005
    • 35
    Check you php-errors ?
    • magua
      • May 2005
      RE: db.inc.php error
      php log file is empty.
      From my info.php file
      error_log /var/log/php/php.log /var/log/php/php.log
      log_errors On On
      • johnl
        • Jan 2005
        • 27
        if memory serves i believe i had this problem when i upgraded from 1 version to another. i think the problem was related to the password. if you reset the password for zabbix on your mysql/postgres database to what it should be, this should fix it.
        regards
        john
