zabbix_server doesn't start with postgresql
  • surenx
    • Oct 2007
    Hi
    I have zabbix web interface installed and configured to work with postgresql database, zabbix user is created along with it's password and entered in /usr/local/share/zabbix/php/conf/zabbix.conf.php.
    Web interface works very well, but I can't start the zabbix_server script, in the log file I get the following.
    Failed to connect to database: Error: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2) [2002]
    when I edit the /usr/local/etc/zabbix/zabbix_server.conf file I see that I can only change the username and password but not the DB type, and it seems that zabbix_server only wants to connect to Mysql DB.
    Can anyone tell me, how can I make zabbix_server connect to postgresql database.
    Thanks in Advance
  • malmo
    • Nov 2007
    1, is your zabbix server compiled with postgres support?
    2, are you able to connect to postgres database using dbname, username and password specified in zabbix_server.conf file?
    • surenx
      • Oct 2007
      Yes, it is compiled with postgres support and web interface connects to the postgresql database and works normally, but zabbix_server only wants to connect to mysql I don't know how to change the configuration to postgresql in zabbix_server.conf file
      • surenx
        • Oct 2007
        Problem is solved, actually you need to be really careful how you compile zabbix.
        So it be better compiled only with postgresql support if you intend to use that database
