User Parameter issue on debian linux
  • tagsense
    • Nov 2007
    hello,
    i am running Zabbix server (version 1.4.2) on a debian stable machine (2.6.18-5 kernel) and running the client (version 1.4.2) on a debian test machine (2.6.15-1).
    i defined the following userparameter in the zabbix_agentd.conf:
    UserParamater=rs.meminfo,vmstat -s | grep -i 'free memory' | awk '{print $1}'
    when i activate it on the server side, i get ZBX_NOTSUPPORTED return code from the client.
    i have verified the following:
    1. 'zabbix' user has rights to execute all the commands (vmstat, free and awk) included in the definition.
    2. server side data type is correct - number 64-bit integer
    3. server and client can talk to each other - two system parameters (system.swap.out and system.swap.in) are getting reported correctly.
    this parameter doesn't work even if i simplify the definition to the following:
    UserParamater=rs.meminfo,echo 1
    could anyone pls. help me resolve this?
    thanks in advance
    dave
  • martin.marcher
    • Nov 2007
    • 22
    Originally posted by tagsense
    hello,
    dave
    The $1 is replaced by ZABBIX. I think your best options is to create a wrapper script that does what you defined.
    Try this to see what I mean:
    UserParamater=echotest[*],echo $1
    whatever you give will be echoed back to you....
    • tagsense
      • Nov 2007
      my apologies.
      i had misspelt userparameter as userparamAter. thats what was causing the problem.
      • martin.marcher
        • Nov 2007
        • 22
        my apologies.
        Hehe, better I read what I copy next time too - the typos are in my post too
