mysql error
  • zabbixtester
    • Nov 2007
    mysql error
    mysql-server-5.0.27-1.fc6
    mysql> use zabbix;
    Database changed
    mysql> CREATE TABLE slideshows (
    -> slideshowidbigint unsignedDEFAULT '0'NOT NULL,
    -> namevarchar(255)DEFAULT ''NOT NULL,
    -> delayintegerDEFAULT '0'NOT NULL,
    -> PRIMARY KEY (slideshowid)
    -> ) type=InnoDB;
    ERROR 1064 (42000): You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'unsignedDEFAULT '0'NOT NULL,
    delayintegerDEF' at line 2
    mysql>
    mysql> CREATE TABLE dhosts (
    -> dhostidbigint unsignedDEFAULT '0'NOT NULL,
    -> druleidbigint unsignedDEFAULT '0'NOT NULL,
    -> ipvarchar(15)DEFAULT ''NOT NULL,
    -> statusintegerDEFAULT '0'NOT NULL,
    -> lastupintegerDEFAULT '0'NOT NULL,
    -> lastdownintegerDEFAULT '0'NOT NULL,
    -> PRIMARY KEY (dhostid)
    -> ) type=InnoDB;
    ipvarcha' at line 2
    mysql>
    Does anyhone have a mysql file for use with fedora core 6?
    Regards,
