I've got something special when a file decame higher that 2Go it's recognize as size of 8388608 To (!) Does somebody get same problem?
Information :
Zabbix server 1.4.2
Zabbix agent 1.4.2
Filesystem Type NTFS
Windows 2000 server
Result log :
2007.Dec.10 18:04:09 9223372036854775807
2007.Dec.10 18:03:39 9223372036854775807
2007.Dec.10 18:03:10 9223372036854775807
2007.Dec.10 18:02:39 9223372036854775807
2007.Dec.10 18:02:09 2139103232
2007.Dec.10 18:01:40 2115510272
2007.Dec.10 18:01:32 2108956672
Item used:
vfs.file.size[I:\oracledb\MIGJV\oradata\TEMP01.DBF]
Zabbix_get result :
# zabbix_get -s ****** -k "vfs.file.size[I:\oracledb\MIGJV\oradata\TEMP01.DBF]"
18446744071709007872
Real size:
2,13 Go (2 294 423 552 octets)
in attachement :
-trigger window
-Item conf
Regards.
Ben
Information :
Zabbix server 1.4.2
Zabbix agent 1.4.2
Windows 2000 server
Result log :
Item used:
Zabbix_get result :
Real size:
in attachement :
-trigger window
-Item conf
Regards.
Ben
