1.4.1 External check Syntax
  • vikty
    • Jul 2007
    • 104
    Hi, forum
    Zabbix-server version:1.4.1
    I have upgarade the 1.4 in 1.4.1 for a problem of "process child death" however....
    I have tried to implement a "External check".
    Problem: External check [zabFW1Ping.sh[]] is not supported
    Log: Parameter [zabFW1Ping.sh[]] is not supported by agent on host
    Well, in the 1.4 the syntax is zabFW1Ping.sh() in 1.4.1 zabFW1Ping.sh() isn't accepted... (Before upgrade The external checks work correctly)
    for this I must use zabFW1Ping.sh[].
    Now If zabFW1Ping.sh[] is an external check, why does zabbix_server ask to the agent the parameter zabFW1Ping.sh[]? :-/
    PS
    I don't want upgrade.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    PS
    Obviously because the item is not defined as an external check.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • vikty
      • Jul 2007
      • 104
      would not the tipe denify the items?
      If I specify Type: External check,
      The server would execute an external check independently to the key.
      I can write any thing in the key "test.sh[]" "unknow.sh[]" an so.
      1)search the scipt test.sh or unknow.sh in /etc/zabbix/externalscripts/
      2)if found execute the script
      In case of Syntax Error, Zabbix tell me the error... but "Parameter [zabFW1Ping.sh[]] is not supported by agent on host"..... it is strange
      Anyway without upgrade I can't set External Check, correct?
      Well I do a workaround... and so
