Zabbix 1.4 running on FreeBSD. Everything was set up by another employee who is no longer here. Yesterday something happened and Zabbix completly crashed. I am trying to rebuild it, but being so new i am running into several problems.
I am trying to do a simple ping to see if my server is up and running.
i have created the host, a new group, and i am pointing to the IP address, status is monitored.
i created 1 item. A simple check, icmpping, status active, everything else is default.
I created a trigger called server is unreachable. the expression is {AV1:icmpping.last(1)}=0
i created an action to email me.....
when i go to monitoring\overview the box is empty. when i go to monitoring\triggers the status is unknown.
the server is also listed in Monitoring\events but the value is unknown.
i get the feeling something is not working correctly. when i reboot the server none of the status fields change and there is no notification sent via email...
i have spent the entire day reading the manual and this forum but so far nothing i have tried has worked. I know this should be a very basic and simple process to set up but for some reason things are not working....
aaarrrrggggghhhhh
thanks everyone.
aaarrrrggggghhhhh
thanks everyone.
