zabbix 1.4.4 rpm for SuSE specfile
  • crosmuller
    • Jan 2008
    Hi everyone,
    I built a specfile for zabbix 1.4.4 server and one for the agent, it is based on jojo's specfiles I found in thread http://www.zabbix.com/forum/showthre...highlight=spec
    The specfile is only tested on a 64bits Suse 10.1 server.
    Maybe it is useful for someone, also any feedback is appreciated. The server rpm only works correctly if there is no password for the mysql root user, I'm not quite sure how to solve that.....
    server specfile
    # spec file for package zabbix 1.4.4
    # Based on a spec file by Sol Tutaki <[email protected]>
    Summary: An enterprise-class open source distributed monitoring solution for networks and applications.
    Version: 1.4
    Release: 4
    License:        GPL
    Vendor:         ZABBIX SIA
    URL:            http://www.zabbix.org
    Packager:       Chantal Rosmuller <[email protected]>
    Group:          System Environment/Daemons
    Source:         zabbix-1.4.4.tar.gz
    Patch0:         zabbix-1.4.4-netsnmp.patch
    BuildPrereq:    mysql, net-snmp-devel, php5, php5-mysql, apache2, php5-gd, php5-bcmath, curl-devel
    Buildroot:      %{_tmppath}/%{name}-%{version}-buildroot
    %description
    The ZABBIX server is a network monitor
    %define _prefix         /opt/zabbix
    %define zabbix_bindir   %{_prefix}/bin
    %define zabbix_confdir  /etc/zabbix
    %define zabbix_initdir  /etc/init.d
    %define zabbix_docdir   %{_prefix}/doc
    %define zabbix_piddir   /var/run/zabbix/
    %define zabbix_logdir   %{_prefix}/log
    %define zabbix_scriptsdir %{_prefix}/scripts
    %define apache_sysconfdir       /etc/apache2
    %define zabbix_datadir          %{_prefix}/misc
    %define zabbix_phpfrontend      %{_prefix}/www
    %define zabbix_libdir           %{_prefix}/lib
    %define dbuser                  root
    %prep
    %setup -q -n zabbix-1.4.4
    %patch0 -p1
    %build
    %configure --prefix=%{_prefix} --with-mysql --enable-server --enable-ipv6  --with-net-snmp --with-libcurl
    make
    %clean
    rm -fr $RPM_BUILD_ROOT
    %pre
    # create ZABBIX group
    if [ -z "`grep zabbix /etc/group`" ]; then
      /usr/sbin/groupadd zabbix >/dev/null 2>&1
    fi
    # create ZABBIX uzer
    if [ -z "`grep zabbix /etc/passwd`" ]; then
      /usr/sbin/useradd -g zabbix -c "Zabbix user account" -s /bin/false zabbix >/dev/null 2>&1
    fi
    %install
    # make pid directory
    install -d %{zabbix_piddir}
    chmod -R 777 %{zabbix_piddir}
    # copy documentation
    install -d %{buildroot}%{zabbix_docdir}
    install -m 644 AUTHORS %{buildroot}%{zabbix_docdir}/AUTHORS
    install -m 644 COPYING %{buildroot}%{zabbix_docdir}/COPYING
    install -m 644 NEWS %{buildroot}%{zabbix_docdir}/NEWS
    install -m 644 README %{buildroot}%{zabbix_docdir}/README
    # copy binaries
    install -d %{buildroot}%{zabbix_bindir}
    install -s -m 755 src/zabbix_server/zabbix_server %{buildroot}%{zabbix_bindir}/zabbix_server
    # copy config files
    install -d %{buildroot}%{zabbix_confdir}
    install -m 755 misc/conf/zabbix_server.conf %{buildroot}%{zabbix_confdir}/zabbix_server.conf
    # copy startup script
    install -d %{buildroot}%{zabbix_initdir}
    install -m 755 misc/init.d/suse/9.3/zabbix_server %{buildroot}%{zabbix_initdir}/zabbix_server
    # SQL scripts
    install -d %{buildroot}%{zabbix_datadir}
    cp -r create/* %{buildroot}%{zabbix_datadir}
    # Log folder
    install -d %{buildroot}%{zabbix_logdir}
    # apache2 config
    cat >zabbix.conf <<EOF
    Alias /zabbix %{zabbix_phpfrontend}
    <Directory "%{zabbix_phpfrontend}">
        Options FollowSymLinks
        AllowOverride None
        Order allow,deny
        Allow from all
    </Directory>
    EOF
    # Place the newly created zabbix.conf file into the httpd conf.d directory
    install -d %{buildroot}%{apache_sysconfdir}/conf.d
    install -m 644 zabbix.conf %{buildroot}%{apache_sysconfdir}/conf.d/zabbix.conf
    # Copy the PHP frontends
    install -d %{buildroot}%{zabbix_phpfrontend}
    cp -r frontends/php/* %{buildroot}%{zabbix_phpfrontend}
    %post
    # configure ZABBIX server daemon
    sed -i  -e "s#AlertScriptsPath=/home/zabbix/bin/#AlertScriptsPath=%{zabbix_bindir}/#g" \
            -e "s#PidFile=/var/tmp/zabbix_server.pid#PidFile=%{zabbix_piddir}/zabbix_server.pid#g" \
            -e "s#LogFile=/tmp/zabbix_server.log#LogFile=%{zabbix_logdir}/zabbix.log#g" \
            -e "s#DBUser=root#DBUser=zabbix#g" \
    # configure the init script
    sed -i -e "s#/var/tmp/zabbix_server.pid#/var/run/zabbix/zabbix_server.pid#g"\
    # Change the DB TYPE to MYSQL and the DB USER to zabbix
    sed -i  -e "s#\$DB_TYPE =\"POSTGRESQL\";#\$DB_TYPE =\"MYSQL\";#g" \
            -e "s#=\"root\";#=\"zabbix\";#g" \
            %{zabbix_phpfrontend}/include/db.inc.php
    sed -i  -e "s#grep zabbix_server#grep zabbix#g" \
            %{zabbix_phpfrontend}/include/config.inc.php
    chkconfig --add zabbix_server
    chkconfig zabbix_server on
    if [ -z "`grep -i "Zabbix server" /etc/services`" ]; then
      cat >>etc/services <<EOF
    zabbix_server          10051/tcp                       # Zabbix server
    EOF
    fi
    # Create the tables inside the database
    cat %{zabbix_datadir}/schema/mysql.sql |mysql -u%{dbuser} zabbix
    # Populate the tables with data and then remove the data directory
    cat %{zabbix_datadir}/data/data.sql |mysql -u%{dbuser} zabbix
    cat %{zabbix_datadir}/data/images_mysql.sql |mysql -u%{dbuser} zabbix
    rm -rf %{zabbix_datadir}
    %{zabbix_initdir}/zabbix_server start
    %preun
    %{zabbix_initdir}/zabbix_server stop || true
    rm -f %{zabbix_piddir}/zabbix.pid
    if [ $1 -eq 0 ] ; then
            chkconfig --del zabbix_server
    fi
    %files
    %defattr(0755,zabbix,zabbix)
    %dir %{zabbix_docdir}
    %attr(0644,zabbix,zabbix) %{zabbix_docdir}/AUTHORS
    %attr(0644,zabbix,zabbix) %{zabbix_docdir}/COPYING
    %attr(0644,zabbix,zabbix) %{zabbix_docdir}/NEWS
    %attr(0644,zabbix,zabbix) %{zabbix_docdir}/README
    %dir %{zabbix_confdir}
    %attr(0644,zabbix,zabbix) %{zabbix_confdir}/zabbix_server.conf
    %dir %{zabbix_bindir}
    %dir %{zabbix_datadir}
    %{zabbix_datadir}/
    %dir %{zabbix_logdir}
    %dir %{zabbix_phpfrontend}
    %attr(0755,zabbix,zabbix) %{zabbix_phpfrontend}/
    %attr(0644,root,root) %{apache_sysconfdir}/conf.d/zabbix.conf
    %changelog
    net snmp patch file (needed for zabbix server)
    --- zabbix-1.4.4/configure      2007-12-17 14:27:26.000000000 +0100
    +++ configure   2008-01-04 15:38:23.000000000 +0100
    @@ -10889,7 +10889,7 @@
       echo $ECHO_N "(cached) $ECHO_C" >&6
     else
       ac_check_lib_save_LIBS=$LIBS
    -LIBS="-lnetsnmp   $LIBS"
    +LIBS="-lnetsnmp -lcurl $LIBS"
     cat >conftest.$ac_ext <<_ACEOF
     /* confdefs.h.  */
     _ACEOF
  • crosmuller
    • Jan 2008
    and the agent
    and zabbix agent
    Summary: ZABBIX network monitor agent
    Version: 1.4
    Release: 4
    License:        GPL
    Vendor:         ZABBIX SIA
    BuildPrereq:    net-snmp-devel, curl-devel
    %description
    The ZABBIX agent
    %prep
    %build
    %configure --prefix=%{_prefix} --enable-agent
    make
    %clean
    %pre
    fi
    fi
    %install
    # copy binaries
    install -s -m 755 src/zabbix_agent/zabbix_agentd %{buildroot}%{zabbix_bindir}/zabbix_agentd
    # copy config files
    install -m 755 misc/conf/zabbix_agentd.conf %{buildroot}%{zabbix_confdir}/zabbix_agentd.conf
    install -m 755 misc/init.d/suse/9.3/zabbix_agentd %{buildroot}%{zabbix_initdir}/zabbix_agentd
    # Log folder
    %post
    # configure ZABBIX agent daemon
    %{__sed} -i -e "s#Hostname=localhost#Hostname=`uname -n`#g" \
                -e "s#PidFile=/var/tmp/zabbix_agentd.pid#PidFile=%{zabbix_piddir}/zabbix_agentd.pid#g" \
                -e "s#LogFile=/tmp/zabbix_agentd.log#LogFile=%{zabbix_logdir}/zabbix_agentd.log#g" \
                -e "s#Timeout=3#Timeout=30#g" \
    %{__sed} -i -e "s#BASEDIR=\/opt\/zabbix#USER=zabbix; BASEDIR=%{prefix}; conffile=\"%{zabbix_confdir}/zabbix_agentd.conf\"#g" \
                -e "s#\$FULLPATH#\$FULLPATH -c \$conffile#g" \
                    -e "s#/var/tmp/zabbix_agentd.pid#/var/run/zabbix/zabbix_agentd.pid#g"\
    chkconfig --add zabbix_agentd
    chkconfig  zabbix_agentd on
    if [ -z "`grep -i "Zabbix agent" /etc/services`" ]; then
    zabbix-agentd          10050/tcp                       # Zabbix agent
    EOF
    fi
    %{zabbix_initdir}/zabbix_agentd start
    %preun
    %{zabbix_initdir}/zabbix_agentd stop || true
    rm -f %{zabbix_piddir}/zabbix_agentd.pid
            chkconfig --del zabbix_agentd
    fi
    %files
    %attr(0644,zabbix,zabbix) %{zabbix_confdir}/zabbix_agentd.conf
    %changelog
    • NOB
      • Mar 2007
      • 469
      Hi Chantal
      thank you for the spec files.
      My comment:
      Originally posted by crosmuller
      and zabbix agent
      some useful stuff omitted
      a lot of useful stuff omitted
      OK, Now I know why the Debian-Agent depends on an LDAP-Client !
      People tend to copy the BuildPrereq from the server to the agent spec-file
      and don't delete all the dependencies.
      The ZABBIX-Agent does not depend on any third-party libraries
      like net-snmp-devel, curl-devel, LDAP-Client, etc.
      Just the server does, depending on the ideas of the packager.
      These lines a not only wrong but really bad: they result in the installation of
      the net-snmp-devel, curl-devel and LDAP-Client software on ALL
      agent systems.
      I don't want that.
      The more software on the systems the more downtime for pro-active
      patching we need.
      Regards
      Norbert.
      • crosmuller
        • Jan 2008
        changed agent specfile
        Thanks Norbert, you are right, I changed the agent specfile:
        Version: 1.4
        Release: 4
        License:        GPL
        Vendor:         ZABBIX SIA
        %description
        The ZABBIX agent
        %prep
        %build
        make
        %clean
        %pre
        fi
        fi
        %install
        # copy binaries
        # copy config files
        # Log folder
        %post
        EOF
        fi
        %preun
        fi
        %files
        %changelog
        • crosmuller
          • Jan 2008
          fixed mysql problem
          The specfile for the zabbix server now also works when the mysql root user has a password:
          # Copyright (c) 2003 SuSE Linux AG, Nuernberg, Germany.
          # This file and all modifications and additions to the pristine
          # package are under the same license as the package itself.
          # Please submit bug fixes or comments via http://www.suse.de/feedback/
          Version: 1.4
          Release: 4
          License:        GPL
          Vendor:         ZABBIX SIA
          %description
          %define dbuser                  root
          %prep
          %patch0 -p1
          %build
          make
          %clean
          %pre
          fi
          fi
          %install
          # copy binaries
          # copy config files
          # SQL scripts
          # Log folder
          # apache2 config
              AllowOverride None
              Order allow,deny
              Allow from all
          </Directory>
          EOF
          %post
          EOF
          fi
          # Create the mysql config file
          install -d  %{_prefix}/scripts/
          echo "#!/bin/bash" >  %{_prefix}/scripts/configure_mysql.sh
          echo "## Variables" >> %{_prefix}/scripts/configure_mysql.sh
          echo "_prefix=/opt/zabbix" >> %{_prefix}/scripts/configure_mysql.sh
          echo "zabbix_datadir=\$_prefix/misc" >> %{_prefix}/scripts/configure_mysql.sh
          echo "## get mysql user and password" >> %{_prefix}/scripts/configure_mysql.sh
          echo "echo \"For creating the Zabbix database we need a username and password.\"" >> %{_prefix}/scripts/configure_mysql.sh
          echo "echo \"\"" >> %{_prefix}/scripts/configure_mysql.sh
          echo "echo \"What is the username? [root]\"" >> %{_prefix}/scripts/configure_mysql.sh
          echo "read username" >> %{_prefix}/scripts/configure_mysql.sh
          echo "if test -z $username" >> %{_prefix}/scripts/configure_mysql.sh
          echo "then" >> %{_prefix}/scripts/configure_mysql.sh
          echo "        username=root" >> %{_prefix}/scripts/configure_mysql.sh
          echo "fi" >> %{_prefix}/scripts/configure_mysql.sh
          echo "echo \"What is the password?\"" >> %{_prefix}/scripts/configure_mysql.sh
          echo "stty -echo" >> %{_prefix}/scripts/configure_mysql.sh
          echo "read password" >> %{_prefix}/scripts/configure_mysql.sh
          echo "stty echo" >> %{_prefix}/scripts/configure_mysql.sh
          echo "# Create the database" >> %{_prefix}/scripts/configure_mysql.sh
          echo "echo \"create database zabbix\" > \$zabbix_datadir/schema/createdb.sql" >> %{_prefix}/scripts/configure_mysql.sh
          echo "mysql -u \$username -p\$password < \$zabbix_datadir/schema/createdb.sql" >> %{_prefix}/scripts/configure_mysql.sh
          echo "# Create the tables inside the database" >> %{_prefix}/scripts/configure_mysql.sh
          echo "mysql -u \$username -p\$password zabbix < \$zabbix_datadir/schema/mysql.sql" >> %{_prefix}/scripts/configure_mysql.sh
          echo "# Populate the tables with data and then remove the data directory" >> %{_prefix}/scripts/configure_mysql.sh
          echo "mysql -u \$username -p\$password zabbix < \$zabbix_datadir/data/data.sql" >> %{_prefix}/scripts/configure_mysql.sh
          echo "mysql -u \$username -p\$password zabbix < \$zabbix_datadir/data/images_mysql.sql" >> %{_prefix}/scripts/configure_mysql.sh
          echo "echo \"We also need a password for the zabbix server to connect to the database:\"" >> %{_prefix}/scripts/configure_mysql.sh
          echo "stty -echo">> %{_prefix}/scripts/configure_mysql.sh
          echo "read zabbixpassword">> %{_prefix}/scripts/configure_mysql.sh
          echo "echo \"Type it again:\"">> %{_prefix}/scripts/configure_mysql.sh
          echo "read zabbixpassword2">> %{_prefix}/scripts/configure_mysql.sh
          echo "if [ \$zabbixpassword != \$zabbixpassword2 ]">> %{_prefix}/scripts/configure_mysql.sh
          echo "then">> %{_prefix}/scripts/configure_mysql.sh
          echo "echo \"passwords do not match\"">> %{_prefix}/scripts/configure_mysql.sh
          echo "exit">> %{_prefix}/scripts/configure_mysql.sh
          echo "else">> %{_prefix}/scripts/configure_mysql.sh
          echo "echo \"grant all privileges on zabbix.* to zabbix@localhost identified by '\$zabbixpassword'\" > \$zabbix_datadir/schema/createuser.sql" >> %{_prefix}/scripts/configure_mysql.sh
          echo "mysql -u \$username -p\$password < \$zabbix_datadir/schema/createuser.sql">> %{_prefix}/scripts/configure_mysql.sh
          echo "rm -f \$zabbix_datadir/schema/createuser.sql"  >> %{_prefix}/scripts/configure_mysql.sh
          echo "fi">> %{_prefix}/scripts/configure_mysql.sh
          chmod +x %{_prefix}/scripts/configure_mysql.sh
          echo ""
          echo "Run %{_prefix}/scripts/configure_mysql.sh to configure the database"
          echo ""
          echo "change the zabbix MySQL password in %{zabbix_confdir}/zabbix_server.conf"
          echo ""
          echo "start zabbix with %{zabbix_initdir}/zabbix_server start"
          echo ""
          %preun
          fi
          %files
