[1.4.1] Zabbix server process
  • niak
    • Nov 2007
    • 30
    Hi all
    I'm newbie on zabbix and i try to stop zabbix server so i do :
    shell>cd /etc/init.d
    >sudo zabbix_server stop
    But zabbix is already running
    How can i stop zabbix server ?
    Someone have any solution ?
    ps: I'm on Ubuntu 7.10
  • niak
    • Nov 2007
    • 30
    No idea ?
    • skogan
      • Nov 2007
      • 70
      [basic UNIX command line lesson]
      In UNIX environments, current directory is NOT, by default, part of default path. So, when you issue commands
      cd /etc/init.d
      what you are running is not the "zabbix_server" script in /etc/init.d, but the zabbix_server binary in /usr/sbin (or wherever).
      So, the correct command would be
      cd /etc/init.d
      sudo ./zabbix_server stop
      or
      sudo /etc/init.d/zabbix_server stop
      [/basic UNIX command line lesson]
      I hope this helpes
      • niak
        • Nov 2007
        • 30
        Thank you for your reply!
        But i have always a problem:
        Guillaume@info-130-ubuntu:/$ sudo /etc/init.d/zabbix-server stop
        Stopping Zabbix server: zabbix_server
        No /usr/sbin/zabbix_server found running; none killed.
        but when i look at my processes : ps -A:
        5199 ? SN 2:53 /usr/sbin/zabbix_server
        5200 ? RN 2:40 /usr/sbin/zabbix_server
        5201 ? SN 2:47 /usr/sbin/zabbix_server
        5202 ? SN 2:55 /usr/sbin/zabbix_server
        5205 ? SN 2:43 /usr/sbin/zabbix_server
        5206 ? SN 0:00 /usr/sbin/zabbix_server
        5208 ? SN 0:00 /usr/sbin/zabbix_server
        5210 ? SN 0:00 /usr/sbin/zabbix_server
        5212 ? SN 0:00 /usr/sbin/zabbix_server
        5216 ? SN 0:00 /usr/sbin/zabbix_server
        5218 ? SN 0:00 /usr/sbin/zabbix_server
        5220 ? SN 0:00 /usr/sbin/zabbix_server
        5222 ? SN 0:07 /usr/sbin/zabbix_server
        5224 ? SN 0:00 /usr/sbin/zabbix_server
        5226 ? SN 0:03 /usr/sbin/zabbix_server
        5227 ? SN 0:01 /usr/sbin/zabbix_server
        5229 ? SN 0:01 /usr/sbin/zabbix_server
        5231 ? SN 0:01 /usr/sbin/zabbix_server
        5234 ? SN 0:01 /usr/sbin/zabbix_server
        5236 ? SN 0:01 /usr/sbin/zabbix_server
        5238 ? SN 0:01 /usr/sbin/zabbix_server
        5240 ? SN 0:00 /usr/sbin/zabbix_server
        sorry but i am really noob on ubuntu, this is my first install !
        • evgeny elkin
          • Jul 2007
          • 52
          The same problem described in http://www.mail-archive.com/debian-b...msg414040.html , but it not solved yet
          • evgeny elkin
            • Jul 2007
            • 52
            p.s I had this problem with 1.4.2 after upgrading to 1.4.4 it's disappear
            • niak
              • Nov 2007
              • 30
              thank for reply !
