External Check times out, then becomes "unsupported" item
  • freak
    • Oct 2007
    • 52
    I wrote a small script giving back the last successful hop of a traceroute output.
    I defined an External Check traceroute.sh[] (traceroute.sh in /etc/zabbix/externalscripts/ is called with the selected hostname/ip automatically).
    Since traceroute needs quite a while to complete, I experienced that the item after some time gets in "Not supported" state. I guess that zabbix times if the script doesn't reply after a certain amount of time.
    Can this be tweaked?
    Additionally, it seems the script is being called seperately by more than one zabbix_server instance at the same time. Instead of just calling it once.
    Is this a bug?
    I experienced this behaviour in recent trunk (@5231).
  • JoelG
    • Aug 2007
    • 32
    Similar Problem
    I have a short external script that is showing a similar problem. It runs fine for a few samples, over a couple of minutes, then changes to the 'not supported' state. The script runs just fine from the command line. Under the worst network conditions, I don't expect it to take more then a second or two to complete.
    This is a problem that has been reported multiple times, and I have not seen a real solution to the problem.
    In addition, the external script parser does not seem to like floating point values as input, so I have my script multiply by 10, then have Zabbix do an internal conversion with a multiplier of 0.1. It works, but is clearly a work around.
    Running version 1.4.4
    • BusteR81
      • Apr 2007
      • 150
      same here
      Is this a bug?
      i have a sh that send an traceroute email using sendmail if connectivity Down. however if a link is Down, i will receive 2 emails instead of 1. anyone knows how to stop "script is being called seperately by more than one zabbix_server instance at the same time." ??
