I have just started to look at using ZABBIX, and how no previous experience of it. I'm currently using Nagios.
Once I got it all running on the monitoring host, I thought it was time to add in a second host. I fired up the zabbix_agentd on the host and added it.
When I added the host into zabbix, and set it to use the Tempalte_FreeBSD the Zabbix server process dies with this error :-
Any thoughts about how I might diagnose what's causing the problem?
and a second issue I have not been abel to figure out it when I try to use system.cpu.util[,wait,avg1] from the template I get an error
zabbix_agentd -t "system.cpu.util[,wait,avg1]"
system.cpu.util[,wait,avg1] [m|Collector is not started!]
But I see the collector starting in the logs :-
However I don't see anything claiming to be a collector running.
ps -auxwww | grep zabbix_agent
So any thoughts on this one also would be greatly appreciated.
Regards
Ben
69728:20080111:154117 Query::insert into trends (clock,itemid,num,value_min,value_avg,value_max) values (1200063600,19952,1,9223372036854775808.000000,9223372036854775808.000000,9223372036854775808.000000) 69728:20080111:154117 Query failed:PGRES_FATAL_ERROR:ERROR: numeric field overflow DETAIL: The absolute value is greater than or equal to 10^18 for field with precision 16, scale 4. 69728:20080111:154117 Query::update items set nextcheck=1200067352,prevvalue=lastvalue,lastvalue='9223372036854775807',lastclock=1200066077 where itemid=19952 69728:20080111:154117 Query failed:PGRES_FATAL_ERROR:ERROR: current transaction is aborted, commands ignored until end of transaction block 69728:20080111:154117 Query::select distinct function,parameter,itemid,lastvalue from functions where itemid=19952 69728:20080111:154117 Query failed:PGRES_FATAL_ERROR:ERROR: current transaction is aborted, commands ignored until end of transaction block 69723:20080111:154117 One child process died. Exiting ... 69723:20080111:154119 ZABBIX Server stopped
53965:20080111:123522 ZABBIX Agent stopped 54601:20080111:123524 zabbix_agentd started. ZABBIX 1.4.4. 54602:20080111:123524 zabbix_agentd collector started
zabbix 54603 0.1 0.1 2700 1444 ?? SN 12:35PM 0:30.17 zabbix_agentd: processing request (zabbix_agentd) zabbix 54601 0.0 0.1 2700 1312 ?? IN 12:35PM 0:00.00 zabbix_agentd: main process (zabbix_agentd) zabbix 54602 0.0 0.1 2700 1336 ?? SN 12:35PM 0:00.21 zabbix_agentd: main process (zabbix_agentd) zabbix 54604 0.0 0.1 2700 1444 ?? SN 12:35PM 0:26.08 zabbix_agentd: processing request (zabbix_agentd) zabbix 54605 0.0 0.1 2700 1444 ?? SN 12:35PM 0:28.96 zabbix_agentd: processing request (zabbix_agentd) zabbix 54606 0.0 0.1 2828 1340 ?? SN 12:35PM 0:00.04 zabbix_agentd: poller [sleeping for 60 seconds] (zabbix_agentd)
Regards
Ben
