Zabbix server stops receiving active data
  • evdzon
    • Jun 2007
    Hi All,
    I'm currently testing some things with zabbix. I've installed zabbix 1.4.4 on a Centos 5 box.
    Monitoring my local servers are no problem but i now activated some checks thru 'zabbix agent(active)' settings. One server is local and 6 remote servers.
    The problem is that after approx. 1.5 hours my zabbix server stops receiving/processing the data from the active checks (both local and remote) but normal zabbix agent data (where server queries the agent) are no problem.
    I only need to restart my zabbix server process and active data is being processed again (for 1.5 hours).
    Does somebody encounter these issues?
    I hope somebody can help me with this problem.
    Kind regards,
    Erwin
  • Petya
    • Dec 2007
    • 37
    This could happen because of the following error:
    Do you experience high Load Average when zabbix server
    stops processing data?
    Are there any errors in zabbix_agentd(s) log file(s)
    during the time when zabbix_server doesn't process data?
    • Petya
      • Dec 2007
      • 37
      Similar issue here: http://www.zabbix.com/forum/showthread.php?t=8699
