Problem in zabbix_server.log
  • husse
    • Jan 2008
    • 15
    When i run the following command:
    tail -f /var/log/zabbix/zabbix_server.log
    I see the following result..
    29127:20080117:103821 Get value from agent failed. Error: Cannot connect to [192.168.2.168:10050] [No route to host]
    29127:20080117:103824 Get value from agent failed. Error: Cannot connect to [192.168.2.169:10050] [No route to host]
    29127:20080117:103827 Get value from agent failed. Error: Cannot connect to [192.168.2.170:10050] [No route to host]
    29127:20080117:103830 Get value from agent failed. Error: Cannot connect to [192.168.2.171:10050] [No route to host]
    29127:20080117:103833 Get value from agent failed. Error: Cannot connect to [192.168.2.172:10050] [No route to host]
    29127:20080117:103836 Get value from agent failed. Error: Cannot connect to [192.168.2.173:10050] [No route to host]
    29127:20080117:103839 Get value from agent failed. Error: Cannot connect to [192.168.2.174:10050] [No route to host]
    29127:20080117:103842 Get value from agent failed. Error: Cannot connect to [192.168.2.175:10050] [No route to host]
    29127:20080117:103845 Get value from agent failed. Error: Cannot connect to [192.168.2.176:10050] [No route to host]
    29127:20080117:103848 Get value from agent failed. Error: Cannot connect to [192.168.2.177:10050] [No route to host]
    29127:20080117:103851 Get value from agent failed. Error: Cannot connect to [192.168.2.178:10050] [No route to host]
    29127:20080117:103854 Get value from agent failed. Error: Cannot connect to [192.168.2.179:10050] [No route to host]
    A new line is being added to the log file almost every second but it is not telling me so much to understand the problem. It is trying all the IP numbers.. Why do I see this error?
    Zabbix_agentd is running properly, I checked it.. As I know Zabbix_agentd is the recommended one and zabbix_agent should not be used. Should I specify in a config file or somewhere else saying that I am NOT using zabbix_agent and using zabbix_agentd..?
    Thanks a lot in advance..
    hs
  • bbrendon
    • Sep 2005
    • 873
    Can you connect to that IP and port from the zabbix server?
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Tenzer
      • Nov 2007
      • 316
      It seems like you have set up auto discovery, and that it is searching out your network, in order to try and find Zabbix clients on any IP address.
      • husse
        • Jan 2008
        • 15
        Thanks for both answers..
        Do you know how to disable this auto discovery stuff..? I checked the log file but couldn't see any relevant parameter about the auto discovery option..
        Actually.. I assume that it should be disabled by default and I should enable it if I need.. Why is it enabled?
        This was really helpful..
        Regards,
        hs
        • Tenzer
          • Nov 2007
          • 316
          It is disabled in the webinterface under Configuration -> Discovery. It don't think that it is enabled as default, at least I don't recall that.
          • husse
            • Jan 2008
            • 15
            Thanks a lot! Now it is solved..
            • husse
              • Jan 2008
              • 15
              But I have bigger problems.. :S
              Could you check the following thread?
              Maybe you can recommend me sth.. I am stucked on that...
              Thanks again..
              • yas
                • Apr 2010
                • 25
                Get value from agent failed: Cannot connect to [xxx.xx.xx.x:10050] [Interrupted syste
                i have same problem zabbix server not connect to agents plz help me im so tire from other solution are not worked proper
                • yas
                  • Apr 2010
                  • 25
                  zabbix server is running = No
                  hello there i have same problem : my zabbix server does not run plz help me
                  • tchjts1
                    • May 2008
                    • 1605
                    If you want someone to help you, you are going to have to provide more information other than "My server does not run".
                    Look through your Zabbix server and Zabbix agent logs and start pinpointing the problem.
                    • yas
                      • Apr 2010
                      • 25
                      hello there any body can help me plz? i can't added hosts on zabbix server
