zabbix 1.4.4: Frontend initial setup fails connecting to MySQL database.
  • zabbix_es
    • Apr 2007
    • 153
    When you run initial setup of front-end from explorer, first you do an initial test of connection to MySQL database and the result is OK. Though when you push "next", it retuns "Acces denied for user zabbix ... db.inc.php:45".
    I don't understand why, because previous test was successful.
  • Petya
    • Dec 2007
    • 37
    It's a feature! Not a bug
    Before pushing "Next" button retype the password
    (even if it said "OK" when you chose "Test connection").
