Zabbix 1.4.4 not usable
  • maxpower
    • Jul 2007
    • 31
    i had to switch back to 1.4.1 because 1.4.4 caused many problems.
    - Graphics (PNG) are not correctly created as my browser says but something is sent if i look at the source that the browser receives.
    - Nearly all memory triggers are active and report false alarms (php frontend)
    - No mails are beeing sent.
    At least for Solaris 10 hosts this is not usable. I had no time for more debugging.
  • just2blue4u
    • Apr 2006
    • 347
    Do you expect answers on this thread?
    If so:
    I suppose you did also update the frontend, didn't you?
    Greets,
    Heiner
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      I am very surprised by the report. ZABBIX 1.4.4 is considered to be the most stable release so far.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • maxpower
        • Jul 2007
        • 31
        No, i was just bored and found this forum.
        If so:
        Greets,
        Heiner
        Do you get zabbix 1.4.4 without new frontend included ?
        I also created a bug report on sourceforge for the configure script which doesn't work (strips of -lcrypt from net-snmp-config).
        Nobody installs from source to notice that ?
        Whatever, i cannot debug this because i have no test environment for 1.4.4.
        The frontend is installed in the HOME of zabbix and so you call it like http://zabbix_server/~zabbix maybe this has an influence.
