Zabbix And Mysql Server
  • maruscya
    • Jul 2007
    • 129
    Hello Guys..
    After some tests... i buy a new server for Zabbix. I buy Hp DL140 with 5Gb of Ram and quadcore cpu. I hope that server can manage 50 servers.
    IMHO, i can increase performance if Mysql is correctly setup. This is my questions
    Which is the best configuration for mysql server? Do you have some suggestion abou t mysql configuration file ?
    Thanks !
    AndreA
  • bbrendon
    • Sep 2005
    • 873
    Search the forums then let us know what you think
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • maruscya
      • Jul 2007
      • 129
      Many thanks. I found some tricks on forum !http://www.zabbix.com/forum/showthread.php?t=4435
      • mikecrowe
        • Dec 2007
        • 34
        Suggestion: http://forge.mysql.com/projects/view.php?id=44
        • maruscya
          • Jul 2007
          • 129
          Originally posted by mikecrowe
          I' m using tuning-primer.sh and it works realy fine.
          Now i'm searching tuning about mysql ... for zabbix only
          After some tests, mysql can increase performance of zabbix server if setup is correctly.... i need found the best configuration for mysql in zabbix enviroment.
          Thanks for you replay...
          And... i'm sorry about not realy good english ..
