Discovery and Create Hosts
  • jimsander
    • Jan 2008
    I'm new to Zabbix so forgive me if its obvious to the community...
    Outside of the RHES5 Linux Zabbix server and agent, I've got two AIX 5.2 and one windows xp agent (I assume) are correctly configured, but only the 'ZABBIX_Server' showed up in the Monitoring -> Hosts panel. Is it neccessary to add a host ('create host') when you'd think the discovery should apply it to the appropriate group ('AIX', 'Windows Servers', etc).
    IF I use 'create host', then never show up as available, and the Monitoring->Discovery page doesn't find them as Zabbix agents either.
    As a test if I change the port on the remote agents from 10050 to 10051, and restart the agent, then I start seeing "connection refused messages' in the server log as I would expect. So, I know there is valid communication.
    Here is an iteration from my agent log file:
    2187398:20080130:161337 In refresh_metrics('192.168.99.177',10051)
    2187398:20080130:161337 get_active_checks('192.168.99.177',10051)
    2187398:20080130:161337 Sending [ZBX_GET_ACTIVE_CHECKS
    cemcp32
    2187398:20080130:161337 Before read
    2187398:20080130:161337 In parse_list_of_checks() [ZBX_EOF
    2187398:20080130:161337 In disable_all_metrics()
    2187398:20080130:161337 Parsed [ZBX_EOF]
    2187398:20080130:161337 In process_active_checks('192.168.99.177',10051)
    2187398:20080130:161337 In get_min_nextcheck()
    2187398:20080130:161337 Sleeping for 60 seconds
    1310728:20080130:161406 Processing request.
    1310728:20080130:161406 In check_security()
    1310728:20080130:161406 Requested [system.uname]
    1310728:20080130:161406 Before
    1310728:20080130:161406 Run remote command [uname -a] Result [28] [AIX cemcp32 2
     5 00CA]...
    1310728:20080130:161406 Sending back [AIX cemcp32 2 5 00CA4F5D4C00]
