when i run the zabbix_agend on my hp itianium i get the following error
i'm not a hp-ux expert and i can't compile it.
I hope that someone have a solution for this. zabbix runs perfect on a my linux/windows servers but it won't run on my hp-ux servers.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'child_signal_handler' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied data symbol 'errno' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'collector_thread' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'listener_thread' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'active_checks_thread' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'EXECUTE_STR' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied data symbol '__iob' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied data symbol '__SB_masks' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'add_alias_from_config' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'KERNEL_MAXFILES' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'KERNEL_MAXPROC' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VFS_FS_SIZE' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VFS_FS_INODE' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VFS_DEV_READ' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VFS_DEV_WRITE' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'NET_TCP_LISTEN' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'NET_IF_IN' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'NET_IF_OUT' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'NET_IF_TOTAL' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'NET_IF_COLLISIONS' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VM_MEMORY_SIZE' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'PROC_NUM' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'PROC_MEMORY' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_CPU_SWITCHES' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_CPU_INTR' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_CPU_UTIL' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_CPU_LOAD' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_CPU_NUM' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_SWAP_SIZE' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_SWAP_IN' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_SWAP_OUT' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_UPTIME' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_CPU_LOAD1' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_CPU_LOAD5' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_CPU_LOAD15' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_LOCALTIME' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'RUN_COMMAND' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'WEB_PAGE_GET' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'WEB_PAGE_PERF' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'WEB_PAGE_REGEXP' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VFS_FILE_EXISTS' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VFS_FILE_TIME' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VFS_FILE_SIZE' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VFS_FILE_REGEXP' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VFS_FILE_REGMATCH' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VFS_FILE_CKSUM' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'VFS_FILE_MD5SUM' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'CHECK_DNS' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'CHECK_PORT' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_HOSTNAME' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_UNAME' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'SYSTEM_UNUM' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'CHECK_SERVICE' in load module './zabbix_agentd'.
/usr/lib/hpux32/dld.so: Unsatisfied code symbol 'CHECK_SERVICE_PERF' in load module './zabbix_agentd'.
