Zabbix and MySQL, Crashed tables
  • michaeltje
    • Aug 2007
    • 44
    Hi There,
    My Zabbix box sometimes stops storing the data in the MySQL database, when i check the zabbix_server.log it shows me the follow:
    PHP Code:
      6752:20080214:095201 Query::select min(value) from history_uint where clock>1202978881 and itemid=19680
      6752
    :20080214:095201 Query failed:Table './zabbix/history_uint' is marked as crashed and should be repaired [145]
    6752:20080214:095201 Query failed: [insert into history_uint (clock,itemid,value) values (1202979121,21450,24264587)] Table './zabbix/history_uint' is marked as crashed and should be repaired [145]
    6752:20080214:095201 Query failed: [insert into history_uint (clock,itemid,value) values (1202979121,20190,1)] Table './zabbix/history_uint' is marked as crashed and should be repaired [145]
    6752:20080214:095201 Query failed: [insert into history_uint (clock,itemid,value) values (1202979121,19860,2)] Table './zabbix/history_uint' is marked as crashed and should be repaired [145]
    6752:20080214:095201 Query failed: [insert into history_uint (clock,itemid,value) values (1202979121,19410,1)] Table './zabbix/history_uint' is marked as crashed and should be repaired [145]
    6753:20080214:095201 Query failed: [insert into history_uint (clock,itemid,value) values (1202979121,20341,1)] Table './zabbix/history_uint' is marked as crashed and should be repaired [145]
    6753:20080214:095201 Query::select max(value) from history_uint where clock>1202978821 and itemid=20341
      6753
    6753:20080214:095201 Query failed: [insert into history_uint (clock,itemid,value) values (1202979121,19561,481473)] Table './zabbix/history_uint' is marked as crashed and should be repaired [145]
    6753:20080214:095201 Query failed: [insert into history_uint (clock,itemid,value) values (1202979121,20521,2)] Table './zabbix/history_uint' is marked as crashed and should be repaired [145]
    6753:20080214:095201 Query failed: [insert into history_uint (clock,itemid,value) values (1202979121,20711,3)] Table './zabbix/history_uint' is marked as crashed and should be repaired [145]
    After that i repair the table and the next day it occurs again, is this a bug in zabbix?
    Any help is apreciated since this is quite a serious problem, thanks!
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    No, it is not bug in ZABBIX!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • michaeltje
      • Aug 2007
      • 44
      Any idea what this could cause? Its quite annoying
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Just a guess, power offs without a proper shutdown?
        Alexei Vladishev
        My Twitter
        • michaeltje
          • Aug 2007
          • 44
          The machine is running 24/7 and has not be switched off for like 4/5 months, so thats not the problem
          • bbrendon
            • Sep 2005
            • 873
            Disk full?
            Unofficial Zabbix Expert
            Blog, Corporate Site
            • michaeltje
              • Aug 2007
              • 44
              it has used 1 of the 5 GB, i see it happens every morning, it happened today again
              • ProTON
                • Oct 2005
                • 77
                We are experiencing the same problem too. We've consulted with our MySQL support and they told that this usually happens when using delayed queries. Does Zabbix server/agent uses any of this type of queries?
                • Alexei
                  Founder, CEO
                  • Sep 2004
                  • 5654
                  Zabbix does not use delayed queries at all.
                  Alexei Vladishev
                  My Twitter
                  • ProTON
                    • Oct 2005
                    • 77
                    So why does it happen? Usually during reboots, normal reboots with shutdown -r now. Also I saw this couple of times on normal working system without any reboots. MySQL tables just crashes randomly.
                    • Alexei
                      Founder, CEO
                      • Sep 2004
                      • 5654
                      I have no idea. Obviously this question has to be addressed to MySQL team.
                      Alexei Vladishev
                      My Twitter
                      • stalker
                        • Aug 2008
                        • 29
                        try to test your hardware! Check your server memory with memtest86.
                        If hardware is ok, recheck mysqld options in mysql.cnf and tune it more accurately.
                        • ProTON
                          • Oct 2005
                          • 77
                          Memory, CPU and PSU is changed. Also other MySQL DBs on that server works fine without a problem.
                          • bbrendon
                            • Sep 2005
                            • 873
                            I'll have to agree with Alexei, this isn't Zabbix. Did you fsck? Do you have a mysql wiz around to look at it?
                            • ProTON
                              • Oct 2005
                              • 77
                              #15
                              I have tried almost everything for the last half a year. Hardware change, fsck, memtest86 and other tests, MySQL version change. Now I tried to swich to InnoDB storage engine instead of MyISAM. If it still crashes then official MySQL support says that this is not a problem with MySQL.
