Annoying error message: action type
  • NOB
    • Mar 2007
    • 469
    I use an action to pass events between ZABBIX and another
    monitoring solution in use today by writing an entry to
    the application log of the server having a problem.
    When a certain trigger is set, the action is executed and works fine.
    However, in the zabbix_server log I see the following error
    message:
     57176:20080218:062628 Type of received value [1] is not sutable for [system.run
    [eventcreate /L APPLICATION /T WARNING /SO ZabbixAgent /ID 994 /D "MS Exchange (
    MBX) - DB Disk Read Performance (>10 ms): ON",nowait]@i11.xyz.org] having type
     [672121377]
     57176:20080218:062628 Returning NOTSUPPORTED
    So, how can I set the type of an action ?
    Is this error message a result of the "nowait" ?
    Does it cause any harm to the server which will show up later ?
    Regards
    Norbert.
  • NOB
    • Mar 2007
    • 469
    Now I can answer this question myself:
    The server will crash after a few days, if this action is enabled !
    I suspect a memory leak, but didn't verify this, yet.
    Norbert.
