checks_external.c correction
  • testos
    • Apr 2007
    • 85
    I'm working for several weeks in a few external scripts for:
    - restart zabbix agent in windows/linux machines from zabbix server
    - stop zabbix agent in windows/linux machines from zabbix server
    - start zabbix agent in windows/linux machines from zabbix server
    - status zabbix agent in windows/linux machines from zabbix server
    - copy a new start/stop/restart zabbix agent script in windows/linux machines from zabbix server
    - remotely zabbix agent installation in windows/linux machines from zabbix server
    I discovered that checks_external.c returned nothing with scripts containing instructions to creating child processes within as sleep, scp, ssh, while, and so on.
    checks_external.c use popen() function for "open'' a process by creating a bidirectional pipe, forking, and invoking the shell, but it don't wait for the last child spawned by the parent script.
    I patched checks_external.c adding wait(NULL); instruction just below popen and now everything works perfectly.
    PHP Code:
        if (NULL == (fp = popen(cmd, "r")))
    zbx_snprintf(error,MAX_STRING_LEN-1,"External check [%s] is not supported, failed execution", item->key);
    zabbix_log( LOG_LEVEL_DEBUG, "%s", error);
    SET_STR_RESULT(result, strdup(error));
            return
    NOTSUPPORTED;
    wait(NULL);
    /* we only care about the first line */
