Web Interface takes too long to open
  • Umair
    • Feb 2007
    • 86
    Hi.!
    When i access Zabbix using the front end, the configuration pages open up taking usual time.
    But when i try to open the Monitoring section, the web page gets stuck up and takes a long time to open.
    Apache processes remain the same and i donot see any error on Apache logs...
    Any suggestions ?
    Zabbix 1.4.4
    RedHat EL
  • dsipe
    • Oct 2006
    • 184
    What database engine are you using ?
    if Mysql, i recommend you using one of the default configuration file [ like the medium/large one ].
    Cause if mysql hasn't got enough memory to work, performances get disastrous !
    • Umair
      • Feb 2007
      • 86
      i am using Mysql.
      Earlier the configuration file was medium.
      I changed it to Large to equal 512 MB, but i still don't see any considerable change in performance.
      • xs-
        • Dec 2007
        • 393
        Check:
        - Large config for mysql doesnt automagically phys increase mem in server. how much phys mem does the server has compared to the config?
        - Are you running apache and mysql on the same server?
        - How many monitored hosts / items (if lots, the above is . . . less desirable)
        - when this is happening, check the resource usage of mysql (top, iostat, etc)
        - check mysql processlist: mysql> show processlist;
        and ofcourse when creating the database (or dumping / restoring), edit the schema.sql / dump file and make sure the InnoDB storage engine is used when creating the tables.
        Apache is rarely the bottleneck (its more of a catalyst ). The database is heavily used and when queried for large / many resultsets can make response feel slow / dieing.
