CPU load on Windows agent
  • pasqu
    • Jun 2007
    • 29
    Hi, I have upgrade my windows agent from 1.1.4 to 1.4.4 and after this all my CPU load are increase (in every windows server).
    Is normal? I see that now the CPU loads are double from version 1.1.4.
    Any suggestions?
    Thanks Enrico.
  • xs-
    • Dec 2007
    • 393
    Does the windows servers have multiple processors / cores (or hyperthreading)?
    Dont know about the 1.1.4 agent, but the 1.4.4 agent measures 100% * number of processors as a limit. I dont if this is the agent or the windows perfmon value which causes this.
    • pasqu
      • Jun 2007
      • 29
      No, I see the difference also in server with one CPU and without HT.
      I use the items system.cpu.load[,avg1], so I don't have percentage.
      From 1.1.4 to 1.4.4 is change the mode for retrieve this value?
      Enrico.
