zabbix 1.4.4 Bug Report
  • Dmitriy Kirhlarov
    • Jun 2007
    • 40
    zabbix_server doesn't check data type, returned by client.
    Test case:
    zabbix agent active check. Data type -- numeric fload.
    returned value "1203205254000.000000".
    zabbix_server die with log message:
    46208:20080216:235011 Query::insert into history (clock,itemid,value) values (1203205811,25536,1203205254000.000000)
    46208:20080216:235011 Query failed:PGRES_FATAL_ERROR:ERROR: numeric field overflow
    DETAIL: A field with precision 16, scale 4 must round to an absolute value less than 10^12.
    After changing Data type to Numeric (64bit) zabbix_server die, when updating trends table.
  • xs-
    • Dec 2007
    • 393
    which test are you doing? an agent internal function or a UserParameter?
    If you are using a userparameter check, be sure that you make the number max: int(16,4)
    • Dmitriy Kirhlarov
      • Jun 2007
      • 40
      It's incorrect UserParameter.
      But, I think it's not good behavior for server.
