Can't access administration tab
  • cil1mia
    • Feb 2008
    After logging into the admin website, when I click on the Administration tab in Firefox, I get the "Save File" dialog to save a "report4.php" file. When I save the file and open it it's just a blank php file. In IE I just get "Internet Explorer cannot display the webpage". Any idea's?
    I am also getting the errors;
    Only variable references should be returned by reference[/var/www/zabbix/include/triggers.inc.php:429]
    Only variable references should be returned by reference[/var/www/zabbix/include/triggers.inc.php:341]
    on the Configuration-Triggers page. Pretty much one set of the above errors per trigger on the screen.
    I am running Zabbix 1.4.4 on Fedora Core 4/2.6.17 kernel, Apache 2.0.54 and PHP 5.04.
    Thanx in advance!
    bytor
    UPDATE 2/28/2008! Well I kind of figured out what was going on. I am still having the problem with the reports4.php file, but I got into the Administration part of the admin site by going through the setup.php again, which I am assuming reset the mechanism that remembers the links clicked on in the menu. I can now get into the Administration part of the admin site. I get the above problem with the report4.php when clicking on the Notifications link under Administration.
