Zabbix Agent 1.4.4 on Win2k3 R2 (32bit) crash
  • qix
    • Oct 2006
    • 423
    Hello all,
    Yesterday I setup a new windows agent installation.
    All seemed to be fine till 0:11 tonight. The agent suddenly crashed and was automatically restarted by the service control manager (I set it up that way).
    Unfortunately it keeps crashing ever since.
    I disabled the automatic restart and set debuglevel to 5.
    Attached you will find an excerpt of the eventlog of the agent.
    I have no clue as to why the agent crashes.
    Disabling remote commands does not work either.
    If needed I can supply more info to resolve this issue.
    With kind regards,
    Raymond
  • qix
    • Oct 2006
    • 423
    When I disable the active agent items in my Zabbix Server configuration, the agent starts normally without crashing directly.
    With kind regards,
    Raymond
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Unfortunately the provided information is not enough to troubleshoot this.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • qix
        • Oct 2006
        • 423
        Hi Alexei,
        Can you tell me what you need from me in order to get the problem more clear for the Zabbix Team?
        (logs, items, ???)
        Since I disabled the active items (eventlogs) on the Zabbix server the agent has been running fine up till now. (no errors in eventlog nor events in Zabbix server. Latest data is up to date.)
        So my guess is that the problem lies either in "eventlog monitoring" or in "active agent".
        With kind regards,
        Raymond
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          I need detailed pre-crash log file with Debug set to 4.
          Alexei Vladishev
          My Twitter
          • qix
            • Oct 2006
            • 423
            Hi Alexei,
            I first restarted the agent on the host so it would give it's startup log.
            When this was finished I turned on the eventlog monitoring items.
            Soon after the agent crashed.
            Please find the attached log (It was too big for the forum, so I zipped it).
            Thanks for the help,
            With kind regards,
            Raymond
            • Alexei
              Founder, CEO
              • Sep 2004
              • 5654
              It doesn't look like a log file generated by ZABBIX agent.
              Alexei Vladishev
              My Twitter
              • qix
                • Oct 2006
                • 423
                It's the logging that the agent leaves in the eventlog.
                I cannot get the agent to log directly into a file (see: http://www.zabbix.com/forum/showthread.php?t=7571
                I've tried:
                • logfile=zabbix.log
                • logfile=c:\zabbix.log
                But both won't appear and the agent still logs to eventlog.
                With kind regards,
                Raymond
                • qix
                  • Oct 2006
                  • 423
                  Ok, just out of plain curiosity I changed "logfile" to "LogFile" and guess what?
                  I get a nice logfile!
                  I didn't realize the agent was case sensitive about its config file....
                  Attached is a new crashlog.
                  The end of the log just stops (the agent is dead, I checked), no indication of a process crash or anything....
                  With kind regards,
                  Raymond
                  • Alexei
                    Founder, CEO
                    • Sep 2004
                    • 5654
                    It crashed at 17:10:42? Actually I do not see anything suspicious in the log file.
                    Alexei Vladishev
                    My Twitter
                    • qix
                      • Oct 2006
                      • 423
                      Yes, it crashed at 17:10:42. That is the last log entry in the file and the agent wasn't running anymore.
                      I do not see anything in the log file either.
                      I can however reproduce it.When eventlog items are disabled, everything runs smooth.
                      As soon as I enable evntlog monitoring and the agent checks for active items, the agent crashes without any clues whatsoever.
                      My guess at this point is that the agent cannot handle one of the log entries in the eventlog and therefor crashes.
                      If this is the case, can you help me find out which log entry that could be?
                      With kind regards,
                      Raymond
