Hi again
first I need to say that I read a lot of post about "Connection refused" troubles of many Zabbix users. I think that my trouble is iptables but I want to tell the way to install zabbix agent in Debian by apt-get if need be.
I have a zabbix sever running on Centos 5 without troubles and in same way, 5-10 zabbix agents on Windows and Linux(Centos 5). I've 3 Debian servers with IPtables rules on. For me is the first difference between servers. I read some guides to install zabbix agent in Debian and it seems is very easy but don't work for me
guide 1
guide 2
I use apt-get to install zabbix_agent and after edited the properly .conf. But my zabbix server show:
Debian 1)Cannot connect to [91.192.110.56:10050] [Connection refused]
Debian 2) Cannot connect to [91.192.110.57:10050] [Interrupted system call]
I edited iptables with this rules:
The zabbix_agent.log don't show any special
Perhaps I need to compile zabbix agent from Zabbix source??? I check the version of Zabbix Agent through Debian apt-get and is 1.4.4, the last.... Any idea?
Thanks!
guide 1
guide 2
iptables -A INPUT -s 217.113.249.47 -j ACCEPT iptables -A OUTPUT -s 217.113.249.47 -j ACCEPT iptables -A INPUT -p tcp --dport 10050:10051 -j ACCEPT iptables -A OUTPUT -p tcp --dport 10050:10051 -j ACCEPT
Perhaps I need to compile zabbix agent from Zabbix source??? I check the version of Zabbix Agent through Debian apt-get and is 1.4.4, the last.... Any idea?Thanks!
