libcurl not found
  • Villain
    • Aug 2006
    • 84
    libcurl not found
    I am trying to install Zabbix 1.4.4 on a new machine, and when doing so, I get an error saying that it cannot find the Curl libraries, even though they are installed.
    System info:
    CentOS 4.6
    Kernel 2.6.9-67
    I downloaded the latest curl and compiled it from source (7.18.0). I installed it to /usr/local/curl to make it easier to find.
    When I run the ./configure script, I am told that Curl can't be found. My command looks like:
    ./configure --prefix=/usr/local/zabbix --enable-server --enable-agent --with-mysql --with-net-snmp --with-libcurl=/usr/local/curl
    Is there something wrong with that line? Do I need to do something different to find the curl libraries?
    /usr/local/curl/bin:
    curl
    curl-config
    /usr/local/curl/include:
    curl/:
    curl.h
    curlver.h
    easy.h
    mprintf.h
    multi.h
    stdcheaders.h
    types.h
    /usr/local/cur/lib:
    libcurl.a
    libcurl.1a
    libcurl.so -> libcurl.so.4.0.1
    libcurl.so.4 -> libcurl.so.4.0.1
    libcurl.so.4.0.1
    pkgconfig/:
    libcurl.pc
    Any thoughts on why my configure won't see the libs?
  • Villain
    • Aug 2006
    • 84
    resolved
    I found the problem.
    you have to actually go through the path so it reads:
    --with-mysql=/usr/local/mysql/bin/mysql_config or --with-libcurl=/usr/local/curl/bin/curl-config
    So, you need more than the path to those files, you need the path INCLUDING those files when doing the install.
