Zabbix Server on Solaris
  • SMB
    • Sep 2007
    • 30
    Having a little problem getting Zabbix to run on Solaris x86.
    First I got it built with the followig commands:
    export CPPFLAGS='-I/opt/csw/include -I/opt/csw/include/curl -I/opt/csw/include/net-snmp -I/opt/csw/include/openssl'
    export LDFLAGS='-L/opt/csw/lib -R/opt/csw/lib'
    export LIBS='-lcrypto -llber'
    ./configure --prefix=/opt/local --enable-server --with-pgsql --with-libcurl=/opt/csw/bin/curl-config --with-net-snmp=/opt/csw/bin/net-snmp-config --with-ldap
    Now launching it outputs this in the logs:
    15660:20080306:182845 One child process died. Exiting ...
    15662:20080306:182845 Got signal. Exiting ...
    15661:20080306:182845 Got signal. Exiting ...
    15665:20080306:182845 In delete_history(history_text,10048,5174774703587328 007,
    134512012)
    15665:20080306:182845 Query [select min(clock) from history_text where itemid=1
    0048]
    15663:20080306:182845 Got signal. Exiting ...
    15665:20080306:182845 In delete_history(history_log,10048,51747747035873280 07,1
    34512012)
    15665:20080306:182845 Query [select min(clock) from history_log where itemid=10
    048]
    15664:20080306:182845 Got signal. Exiting ...
    15665:20080306:182845 In delete_history(trends,10048,5174774703587328365,13 4512
    012)
    15665:20080306:182845 Query [select min(clock) from trends where itemid=10048]
    15665:20080306:182845 Got signal. Exiting ...
    15666:20080306:182845 Got signal. Exiting ...
    15668:20080306:182845 Got signal. Exiting ...
    15670:20080306:182845 Got signal. Exiting ...
    15669:20080306:182845 Got signal. Exiting ...
    zabbix_server dies almost as soon as it's launched, as you can see from the excerpt of the log it did do something just before it died.
    Any ideas?
