Macro's passed from trigger to action
  • xs-
    • Dec 2007
    • 393
    I dont know if someone has posted this issue before but:
    if I use a macro in a trigger message, for exampe 'Load too high {ITEM.VALUE}' it will display correctly in the webpage but it gets sent to a trigger action as literal text.
    So if I use {TRIGGER.NAME} in the action message (which displays the trigger message text) you will receive 'Load too high {ITEM.VALUE}' instead of i.e. 'Load too high 95%' in mail / interface script.
    Anybody got a fix / solution for this?
  • pierre-hoffmann
    • Jan 2008
    • 133
    i've the same problem with trigger and action
    Anybody have solution ? Correction in 1.6 version ??
    Trigger monitoring :
    Trigger configuration :
    Mail send by an action :
    Regards,
    P.Hoffmann
    System & Network Admin.
    __________________________
    Zabbix version 1.8.1
    Hosts monitored 1300
    OS Novell SLES 10 SP2
    • xs-
      • Dec 2007
      • 393
      Well, its working as documented, the item.value is only available in a trigger name and similar functions are only available on notification.
      But there is no macro which works on both.
      Perhaps this should be proposed as a feature request for 1.6 as i didn't see this in the roadmap or changelog.
      • pierre-hoffmann
        • Jan 2008
        • 133
        Yes it could be a good idea !
        Regards,
        P.Hoffmann
