Zabbix & Oracle database : can't print "Most busy triggers top 100" page
  • max
    • Jan 2008
    • 36
    Hey
    It seems the "Most busy triggers top 100" page is not compatible with Oracle database.
    See below :
    http://tof.canardplus.com/show/75fb1...1c5287161.html
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    Tested on Oracle 10g no errors found on this screen.
    Zabbix | ex GUI developer
    • max
      • Jan 2008
      • 36
      Error in the sql statement !
      Yep !
      If you look carefully at the statement, you will notice that the column t.description is written twice... which causes the error.
      Bye !
      • Aly
        ZABBIX developer
        • May 2007
        • 1126
        It's been already fixed, that's why I haven't found it. Try latest code from svn on from the Nightly build.
        • max
          • Jan 2008
          • 36
          I'm wondering if the nightly build are done correctly because I've downloaded them and I still find the error whereas svn://svn.zabbix.com/trunk/frontends/php/report5.php is ok...
          • Aly
            ZABBIX developer
            • May 2007
            • 1126
            Oops,my bad. I looked into beta release, when in 1.4.4 problem still persist. Now it's really fixed
            P.S. there are some more improvements for Oracle in SVN
            • max
              • Jan 2008
              • 36
              This error had NOT been corrected in the new 1.4.5 !
              • Aly
                ZABBIX developer
                • May 2007
                • 1126
                1.4.5 release date is 25 March, 2008, fixed 26.03.2008...
                • max
                  • Jan 2008
                  • 36
                  correct...
