How can I see zabbix_server running properly ?? I can't with nmap localhost...
  • fievel
    • May 2005
    Im using zabbix1.1Alpha10, and Debian Sarge.
  • welshpjw
    • Mar 2005
    • 50
    Not sure exactly what you hope to get from "nmap localhost"? But "netstat -ap|grep zabb" or a "ps -ef|grep zabb" from the localhost should provide you with alot.
    A few more details of what you would like to do may help.
    • araw
      • May 2005
      • 31
      You can either learn to use nmap properly, or better yet use netcat to poll the agent to ensure it's responding properly.
      [root ~]# nmap -sT -p 10050 127.0.0.1 | grep open
      10050/tcp open zabbix_agent
      [root ~]# echo "system[hostname]" | nc 127.0.0.1 10050
      gwaihir.local
      [root ~]#
      • fievel
        • May 2005
        Thanks ! it was what i looking for.
