1.4.5 process dies
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    #16
    From NMAP manual:
    Filtered means that a firewall, filter, or other network obstacle is blocking the port so that Nmap cannot tell whether it is open or closed.
    What "netstat -an|grep 10051" says? Can you "telnet localhost 10051"?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • bbrendon
      • Sep 2005
      • 872
      #17
      Originally posted by Alexei
      From NMAP manual:
      After I restart zabbix, nmap gives the proper response.
      I'll add the netstat -an to the fix script. Hmmm, I'm not sure how to sciprt the "telnet localhost 10051" which is why I used nmap.
      Unofficial Zabbix Expert
      Blog, Corporate Site
      • bbrendon
        • Sep 2005
        • 872
        #18
        I need to have all this automated. We've had tons of downtime. With my script, I only have about 20 minutes every few days which is tolerable. How about this for the test?
        nmap -v -sT -p 10051 127.0.0.1
        The nmap man page says:
        Nmap asks the underlying operating system to establish a connection with the target machine and port by issuing the connect() system call
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          #19
          Thanks. The fact that ZABBIX restart fixed the problem does not necessary mean that it was a ZABBIX fault. I think that it could also be some kind of kernel or network related issue (limits, kernel-level network flooding protection, whatever).
          Alexei Vladishev
          My Twitter
          • bbrendon
            • Sep 2005
            • 872
            #20
            Thanks very much for the feedback. I'll see what I can come up with.
            • Alexei
              Founder, CEO
              • Sep 2004
              • 5654
              #21
              Thank you for the log file.
              Short advice, increase number of trappers to 50. ZABBIX works absolutely fine.
              At some point your network becomes very slow or unreliable causing large number of timeouts, so all of your five trappers hang in a 5 min (currently hard coded) timeout state.
              Case closed.
              Alexei Vladishev
              My Twitter
              • bbrendon
                • Sep 2005
                • 872
                #22
                Case closed.
                Shit, I would have never guessed. Thanks for the advice!!!!
                • bbrendon
                  • Sep 2005
                  • 872
                  #23
                  Ahh, it seems its a good idea to increase MySQL max_connections when increasing trappers!
                  • xs-
                    • Dec 2007
                    • 393
                    #24
                    Just out of curiosity, how much hosts are you monitoring infinity005?
                    I my setup, i've set the max_trappers low on purpose so there are less concurrent db connections and thus less concurrent updates (after some testing, this decreased the load in the db server quite a bit).
                    • Alexei
                      Founder, CEO
                      • Sep 2004
                      • 5654
                      #25
                      This is not correct. Number of trappers does not affect database performance in a direct way at all.
                      Alexei Vladishev
                      My Twitter
                      • bbrendon
                        • Sep 2005
                        • 872
                        #26
                        I don't see a measurable performance hit when bumping trappers from 5 to 50.
                        Number of hosts (monitored/not monitored/templates/deleted) 107(70/10/27/0)
                        Number of items (monitored/disabled/not supported)[trapper] 345(1590/2483/272)[50]
                        Number of triggers (enabled/disabled)[true/unknown/false] 929(514/415)[8/82/424]
                        • xs-
                          • Dec 2007
                          • 393
                          #27
                          the trapper processes are the ones receiving the active agent checks right?
                          If not, which processes receive it then.
                          If less processes do concurrent connections and this concurrent queries on the database, it will reduce the load on the database (a little less parallel, a little more sequential). If tuned right, it will reduce the load on the database, and not impact the zabbix performance too much *i think*
                          • just2blue4u
                            • Apr 2006
                            • 347
                            #28
                            i find this thread very interesting!
                            Made me think about the question:
                            "is there a way to monitor availibility/utilisation of zabbix trappers"?
                            Big ZABBIX is watching you!
                            (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
                            • bbrendon
                              • Sep 2005
                              • 872
                              #29
                              Okay, looks like things are working smoothly!! This is probably the most stable zabbix has been for me in a long time. Yippie!
                              Alexei, how can I tell how many of the trappers are hung because of bad network connections?
                              • Alexei
                                Founder, CEO
                                • Sep 2004
                                • 5654
                                #30
                                Good news indeed!
                                The processes do not hang forever, it is just for 5 minutes (default) and only in case of serious network related problems.
                                I do not see an easy way of calculating number of trappers in the "sleep" state.
                                OS level TCP keep alive settings can decrease number of such trappers and hung network connections very much. Not sure how to setup this in Linux, it is done nicely in HP-UX, for example.
                                Alexei Vladishev
                                My Twitter
