Configuration export/import and multiple triggers with same name
  • kassec
    • Dec 2007
    • 13
    I'm trying to import a configuration which has multiple triggers with the same name (but expressions and severity are different) and I'm only left with the last imported value at the end.
    It looks like the trigger key is only the description field while it should perhaps be description + severity to allow complex setups.
    Talking about latest 1.4.5 here.
  • kassec
    • Dec 2007
    • 13
    1/ I was wrong, should not add priority as second key but expression.
    2/ Patch here : http://zabbix.com/forum/showthread.php?p=32329
