Error in perf_counter[] special chars
  • pierre-hoffmann
    • Jan 2008
    • 133
    I'm searching for solution for special chars ,for example 'éèà' in french in key name, in perf_counter[].
    Example creating:
    Windows US key: perf_counter[\System\Threads]
    Windows French key: perf_counter[\Système\Threads]
    Generate:
    Incorrect key format 'key_name[param1,param2,...]'
    Any workarround .... Any Patch [i'm using Zabbix 1.4.5] ??
    P.Hoffmann
    System & Network Admin.
    __________________________
    Zabbix version 1.8.1
    Hosts monitored 1300
    OS Novell SLES 10 SP2
  • cordeiro
    • Jul 2007
    • 10
    Just modify a line !
    Hi Pierre,
    I have the same problem.
    I resolved it by modifying the line 393 on file /var/www/html/include/defines.inc.php !
    replace: define('ZBX_EREG_PARAMS', '([[ print:]]+){0,1}');
    by: define('ZBX_EREG_PARAMS', '(.+){0,1}');
    Sincerely,
    Jean Pierre
    • pierre-hoffmann
      • Jan 2008
      • 133
      Thanks,
      But what impact of this modification ?? Where is this string used ??
      I'm on a production plateform with 350 hosts & 5000 items;
      i don't wan't have database corruption
      i've see that support of utf8 was in progress in v1.5.1 but not usable at this moment .... Downport to 1.4 ??
      :: Added support of UTF-8
      ZABBIX front-end is UTF-8 ready. Note that ZABBIX database
      and ZABBIX server and agent processes are still not ready
      for correct processing of UTF-8 data.
      Best regards,
      Pierre.
      P.Hoffmann
      • pierre-hoffmann
        • Jan 2008
        • 133
        I've try to modifie php part, but it seem that zabbix_server binary doesn't undertood 'éè..' chars
        and items was allways 'Not supported by ZABBIX agent'
        [Fix:
        it seem that direct edit of mySQL database work
        UPDATE `zabbix`.`items` SET `key_` = 'perf_counter[\\Disque logique(C: )\\% Temps écriture du disque]'
        WHERE `items`.`itemid` =29201 ;]
        Thank for your help.
        Regards,
        Pierre.
        P.Hoffmann
        • luyggy
          • Aug 2007
          with version 1.6 I still have problems. Someone has to fix it with 1.6?
          Regards,
          • sebthebert
            • Feb 2009
            Change your Perflib Registry key instead, like explained here.
            • simtris
              • Jul 2009
              Hum, maybe no
              It's maybe not the better idea : if you don't have the possibility to do it or if you have 1000 french serveurs.
              I love the php modif, I'll tell if the is any unespected effects.
              In my zabbix debian, the file is in : "/usr/share/zabbix/include"
              Regards
