I had a few unsupported items which became supported. They also show correctly in the Zabbix frontend. They show incorrectly however in the MySQL database?
Is this a bug? I am actively monitoring for status 3 items to make sure all my items are functioning properly. I manually checked the item IDs in the frontend and they are active and supported.
zabbix:~# mysql -uzabbix -p -e "use zabbix; select * from items where status=3;" +--------+------+----------------+-----------------------------------------+-----------+--------+-------------+------------+-------+---------+--------+------------+-----------+------------+-----------+--------+------------+---------------+-------+------------+-------+--------------+---------------------+----------------------+-----------------------+-----------------------+---------+--------------------------------+-------------+------------+------------+------------+------------+--------+ | itemid | type | snmp_community | snmp_oid | snmp_port | hostid | description | key_ | delay | history | trends | nextcheck | lastvalue | lastclock | prevvalue | status | value_type | trapper_hosts | units | multiplier | delta | prevorgvalue | snmpv3_securityname | snmpv3_securitylevel | snmpv3_authpassphrase | snmpv3_privpassphrase | formula | error | lastlogsize | logtimefmt | templateid | valuemapid | delay_flex | params | +--------+------+----------------+-----------------------------------------+-----------+--------+-------------+------------+-------+---------+--------+------------+-----------+------------+-----------+--------+------------+---------------+-------+------------+-------+--------------+---------------------+----------------------+-----------------------+-----------------------+---------+--------------------------------+-------------+------------+------------+------------+------------+--------+ | 21495 | 0 | public | interfaces.ifTable.ifEntry.ifInOctets.1 | 161 | 10048 | Email test | email.test | 600 | 90 | 365 | 1207566909 | NULL | 1207566309 | NULL | 3 | 3 | | | 0 | 0 | NULL | | 0 | | | 1 | Not supported by ZABBIX agent | 0 | | 21392 | 0 | | | | 21546 | 0 | public | interfaces.ifTable.ifEntry.ifInOctets.1 | 161 | 10049 | Email test | email.test | 600 | 90 | 365 | 1207566906 | NULL | 1207566306 | NULL | 3 | 3 | | | 0 | 0 | NULL | | 0 | | | 1 | Not supported by ZABBIX agent | 0 | | 21392 | 0 | | | +--------+------+----------------+-----------------------------------------+-----------+--------+-------------+------------+-------+---------+--------+------------+-----------+------------+-----------+--------+------------+---------------+-------+------------+-------+--------------+---------------------+----------------------+-----------------------+-----------------------+---------+--------------------------------+-------------+------------+------------+------------+------------+--------+ zabbix:~#
