Odd behavior with zabbix agent 1.4.5
  • rolandsym
    • Jul 2007
    • 76
    I'm having some slight problem with some of my zabbix agents. It mainly seems to affect Windows SBS 2003. The agent states this info from it's log
    Now this only happens on the SBS 2003 servers and when I update them to 1.4.5 from 1.4.4. I tried using 1.5 but that complains about not finding the "Jason Object" Am I doing something wrong? I hate having to go back to 1.4.4 and having to "occasionally" restart the client due to active check problems.
    7836:20080416:214344 zabbix_agentd started. ZABBIX 1.4.5.
    9172:20080416:214344 zabbix_agentd collector started
    6000:20080416:214345 zabbix_agentd listener started
    9228:20080416:214345 zabbix_agentd listener started
    8760:20080416:214345 zabbix_agentd listener started
    2088:20080416:214345 zabbix_agentd listener started
    5224:20080416:214345 zabbix_agentd listener started
    9940:20080416:214345 zabbix_agentd listener started
    9512:20080416:214345 zabbix_agentd active check started [my-ipaddress-remove:10051]
    9512:20080416:214405 Active check [perf_counter["\System\Processor Queue Length"]] is not supported. Disabled.
    9512:20080416:214405 Active check [perf_counter[\System\Processes]] is not supported. Disabled.
    9512:20080416:214407 Active check [system.uptime] is not supported. Disabled.
    9512:20080416:214449 Active check [perf_counter["\Memory\Page Faults/sec"]] is not supported. Disabled.
    9512:20080416:214449 Active check [perf_counter["\Memory\Pages/sec"]] is not supported. Disabled.
    9512:20080416:214453 Active check [perf_counter["\Memory\Committed Bytes"]] is not supported. Disabled.
    Rolandsym
