Hi everybody,
A great product that would be even better if I could get it to work right
. I've got Zabbix installed and working to some degree. It can poll itself quite well, but I only get broken images for graphs and maps. I've checked and I believe I have GD installed correctly. Is there a good way to check this? I've got it running on CentOS4.
Are there any instructions on installed the client on Windows2003? I've tried running the executable but it doesn't seem to work. Perhaps there is some COM object security settings?
Any help would be greatly appreciated...
Tom
'./configure' '--build=i686-redhat-linux-gnu' '--host=i686-redhat-linux-gnu' '--target=i386-redhat-linux-gnu' '--program-prefix=' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--datadir=/usr/share' '--includedir=/usr/include' '--libdir=/usr/lib' '--libexecdir=/usr/libexec' '--localstatedir=/var' '--sharedstatedir=/usr/com' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--cache-file=../config.cache' '--with-config-file-path=/etc' '--with-config-file-scan-dir=/etc/php.d' '--enable-force-cgi-redirect' '--disable-debug' '--enable-pic' '--disable-rpath' '--enable-inline-optimization' '--with-bz2' '--with-db4=/usr' '--with-curl' '--with-exec-dir=/usr/bin' '--with-freetype-dir=/usr' '--with-png-dir=/usr' '--with-gd=shared' '--enable-gd-native-ttf' '--without-gdbm' '--with-gettext' '--with-ncurses=shared' '--with-gmp' '--with-iconv' '--with-jpeg-dir=/usr' '--with-openssl' '--with-png' '--with-pspell' '--with-xml' '--with-expat-dir=/usr' '--with-dom=shared,/usr' '--with-dom-xslt=/usr' '--with-dom-exslt=/usr' '--with-xmlrpc=shared' '--with-pcre-regex=/usr' '--with-zlib' '--with-layout=GNU' '--enable-bcmath' '--enable-exif' '--enable-ftp' '--enable-magic-quotes' '--enable-sockets' '--enable-sysvsem' '--enable-sysvshm' '--enable-track-vars' '--enable-trans-sid' '--enable-yp' '--enable-wddx' '--with-pear=/usr/share/pear' '--with-imap=shared' '--with-imap-ssl' '--with-kerberos' '--with-ldap=shared' '--with-mysql=shared,/usr' '--with-pgsql=shared' '--with-snmp=shared,/usr' '--with-snmp=shared' '--enable-ucd-snmp-hack' '--with-unixODBC=shared,/usr' '--enable-memory-limit' '--enable-shmop' '--enable-calendar' '--enable-dbx' '--enable-dio' '--enable-mbstring=shared' '--enable-mbstr-enc-trans' '--enable-mbregex' '--with-mime-magic=/usr/share/file/magic.mime' '--with-apxs2=/usr/sbin/apxs'
. I've got Zabbix installed and working to some degree. It can poll itself quite well, but I only get broken images for graphs and maps. I've checked and I believe I have GD installed correctly. Is there a good way to check this? I've got it running on CentOS4. Are there any instructions on installed the client on Windows2003? I've tried running the executable but it doesn't seem to work. Perhaps there is some COM object security settings?
Tom
